getting very rich at 100 load. cant see why?
Old Mar 1, 2011 | 08:57 AM
adcgn45's Avatar
heres a pic of my log you can see the map is at around 14 yet the wideband is dropping into the tens before ive even made 5 psi.ive tried to raise it but nothing works. any ideas why this is happening?
Old Mar 1, 2011 | 08:58 AM
adcgn45's Avatar
log
log
Attached Thumbnails getting very rich at 100 load. cant see why?-capture.jpg
Old Mar 1, 2011 | 09:18 AM
Raptord's Avatar
Hm, boost leak maybe?
Old Mar 1, 2011 | 09:21 AM
adcgn45's Avatar
i did a test but explain to me how that could cause this problem
Old Mar 1, 2011 | 09:28 AM
escodotcarter's Avatar
when you have a leak there is less air flowing in the motor. I does look like a leak somewhere because from that log the boost goes from 5,6,5,6,7,5 psi. post up the rest of the log if u can.
Old Mar 1, 2011 | 10:50 AM
Raptord's Avatar
When you're in vacuum air would be leaking INTO the system, causing it to run leaner. Cruising in closed loop wouldn't be leaner however because the front o2 would adjust fueling to compensate for the extra air leaking in. Under boost however, air leaks OUT of the system, causing it to run richer. Since you're now in open loop and the fueling is derived from the fuel map, it can't compensate for the leak.
Old Mar 1, 2011 | 11:03 AM
Fast_Freddie's Avatar
Veteran: Navy
I am e-tuning the car at the moment and doing a proper boost leak test was the first thing we talked about when the OP was swapping turbos... I agree that it has to be a boost leak, because I have never seen tip-in that rich before, also if you run it through VDR it isn't hitting peak boost until around 5000 rpm, and then holding steady from there...
Old Mar 1, 2011 | 01:00 PM
Boosted Tuning's Avatar
Your issue is with your "open loop load" tables.
Your welcome.
Old Mar 1, 2011 | 04:04 PM
Veteran: Navy
Thanks Jay, that was changed in the map I sent him last night... I dropped the crossover down to 80 load for 2500-3500 and now that area of the map is at like 15.5... haven't seen a log today to see what it did...
However talking with the OP today, he think the turbo may be on its last leg as well...
Old Mar 1, 2011 | 04:49 PM
adcgn45's Avatar
did a boost leak today and found no leaks. imo if i had a leak substantial enough to make this turbo not spool until 5k it would have to be substantial. and easily found. but i found nothing
Old Mar 1, 2011 | 04:57 PM
adcgn45's Avatar
log
heres an entire log. and yes im aware the injectors have had enough lol
Old Mar 1, 2011 | 04:58 PM
adcgn45's Avatar
btw thanks for your help freddie!!
Old Mar 1, 2011 | 06:06 PM
Veteran: Navy
No problem man... just sent an updated rom... let me know how that turns out...
Old Jul 12, 2011 | 07:03 AM
one1fastevo8's Avatar
Im having the same problem. At around 1500-2000rpm it gos to 10.0afr and bogs. I just got a full Buschur 2.1 build stock throttle body and intake manifold. What could be the problem?
Old Jul 12, 2011 | 06:01 PM
tscompusa2's Avatar
could be fuel trim related ( injectors, deadtime, etc) or something you're missing mechanically. whens the last time you performed a leak test or visually inspected your engine bay?
