Want to ditch xede....
Old Mar 8, 2011 | 05:45 PM
Agent-Smith's Avatar
I no longer use all the functionality of the Xede and I would really like to just get my pump gas tune on the stock ecu.
Is there someone (vendor or individual) that could help? I have my stock rom downloaded and the xede maps. I just need to transfer the tune over.
I could do it myself but that is a big risk...
Old Mar 8, 2011 | 05:49 PM
joseph143's Avatar
search bro there are a lot of reliable people out there... it is a PITA taking the rom and adding or subtracting the xede values... been there myself...
Old Mar 8, 2011 | 05:54 PM
Got any tips on good search terms? I tried quite a few.
Old Mar 8, 2011 | 07:03 PM
Raptord's Avatar
Plenty of vendors here that could probably help you... Tom from VRSF (tscompusa) would be my personnal recommendation, he did a fine job with my car when he worked on it.
Old Mar 8, 2011 | 07:36 PM
joseph143's Avatar
search terms? you are just looking for a tuner... go to the vendor section... swirl your cursor around the screne... whomevers thread you stop on... done... you found your tuner... if you want a complete retune instead of conversion from xede to ecu then i would go with English racing for a email tune or your nearest evo performance/tuner shop... the xede is outdated so most people wont even post that they can still tune it... however what you are doing is such a basic operation that you can do it yourself... i know because i did do it myself...
Old Mar 8, 2011 | 08:19 PM
tscompusa2's Avatar
all you need to do is unhook the xede so its no longer piggy backing from the stock ecu or whatever it does then you can purchase a tune from someone and get the car tuned started off with a base map from the tuner then dialing it in for your mods & fuel and then you'll be good to go.
easy process.. no point in trying to pull the tune out of that xede when a tuner can start scratch and give better results.
Old Mar 8, 2011 | 08:20 PM
tscompusa2's Avatar
thanks for the kind words Raptord
smokedmustang
Jun 21, 2007 01:59 PM
jasonrp15
Southeast Region
Feb 28, 2007 08:45 AM
