WGDC#'s for a stock turbo..
Old Mar 31, 2011 | 07:27 AM
sharkm87's Avatar
ok so before i get into it... yes i will boost test, my compressor is in my parents garage..i live 45min from there so I dont have complete access all the time.. however just looking for some information.
i've searched and haven't found anyone with my mods on stock turbo ( cuz its dumb to have stock turbo wit my mods) but this is it.
i use ecu based boost. trying to target 24 psi or so and let it taper....
now in my wgdc right now my table looks like 100% from 0 - 3625rpm than 98.5 all the way down..
now with this setting i will boost 22...23 ish (sometimes) and tapers to 19..
now if i up it to 90wgdc all of a sudden its goin from 28psi to 24psi.
i noticed it all depends on where i start the pull from as well, if i start like 2500 rpms boost will seem to hit higher,,.. if i start at 3k (all 3rd gear) boost will want to be lower
now most the turbos i see are running 50% wgdc, which i guess is because its not a stock turbo and it moves more air..
i am runnin kelford 272's so maybe it alters it in a way.
but wondering if this is normal...or you think theres an issue with my wg (stock) or ecu boost controller.
note: as i will boost test i dont think its the issue ..whenever i did have boost leaks my car knocks..i get no knock now, but will check anyway
..sry for long post
Old Mar 31, 2011 | 07:41 AM
Raptord's Avatar
A boost leak won't necessarily cause your car to knock... I'd say get that done first.
Old Mar 31, 2011 | 07:45 AM
sharkm87's Avatar
trust n believe mine does...
but thats not the question... i want to know on stock turbos are the duty cycles running that high?
Old Mar 31, 2011 | 08:00 AM
SwishaSweet's Avatar
No the duty cycles shouldnt be that high. A boost leak if anything will lower the duty cycle. Did you put an after market O2 housing on the car.
Old Mar 31, 2011 | 08:08 AM
sharkm87's Avatar
ok i didn't think it should be that high...
car has MAP o2 dump....
i'll check older logs from before this setup to see where the cycles were... if i remember correctly 70's..but that was a while ago.
also will check for leaks over weekend
Old Mar 31, 2011 | 03:53 PM
Benja's Avatar
Have you zero'd out your boost error correction table?
Old Mar 31, 2011 | 07:32 PM
Raptord's Avatar
Please explain how a boost leak lowers WGDC... If air is leaking out of the intake system then the turbo has to push more air to reach a given target than if it wasn't leaking... Therefore higher WGDC
Old Mar 31, 2011 | 09:01 PM
PeteyTurbo@KHC's Avatar
not enough info.. What boost solonoid, is error correct on? Sounds like multiple issues.
Old Mar 31, 2011 | 10:56 PM
RJones's Avatar
With my GM 3port I'm hitting 22-23psi at about 48% WGDC in the midrange and about 29psi at 75% on a stock IX turbo. We need more info on your setup. A boost leak would result in having to ramp up the WGDC to maintain your desired boost levels. I'd check there first.
Old Mar 31, 2011 | 11:26 PM
sparky's Avatar
As a practical matter what is the OP trying to achieve? Is he looking for quickest spool?
Old Apr 1, 2011 | 12:09 AM
And's Avatar
And
are you running the standard 0.8bar actuator? if so might be worth an upgrade to a better one, something like a 1.5bar etc that will also reduce the WGDC
Old Apr 1, 2011 | 04:49 AM
sharkm87's Avatar
thx for all the replies guys..
this was the main info i was looking for here... and yes i know i need a boost leak test done but was looking mainly to see on a stock turbo what WDGC's where people using .. so i def have an issue there as when i set to 75 all the way up to 100 its still like 20psi.. i know for a fact my t bolts are clamped down and i double bolt them so it doesnt back out.. so its either my used IC with an issue or bov but will boost test tomorrow.
i am using the gm 3 port as well with a stock wga... i have a fp18 psi wga as well, will prob throw that on tomorrow too
Old Apr 1, 2011 | 04:57 AM
sharkm87's Avatar
oh and all my correction tables were 0'd out... i have to have a huge leak somewhere...sucks its been like this a while but will get to the bottom of this tomorrow... than moar tunin funz
Old Apr 1, 2011 | 09:59 AM
RJones's Avatar
I'm using the Forge adjustable WGA w/ the 19-24psi spring. I'm sure that will make some difference, but I'm pretty sure you've got a boost leak.
Old Apr 1, 2011 | 10:21 AM
sharkm87's Avatar
yup.. i'm almost 100% sure thats what it is now.. i'm so amped now to get it resolved and hit track again for some real times.... i'm also suspect of my bov..its an old 9 dv.. but i'll see and post back results.
