Setting base timing with ECU flash *IN A DSM*
Old Apr 7, 2011 | 01:04 PM
sobo's Avatar
Quick question all.
I have a DSM that I swapped a 6 bolt into and a Evo 8 ecu. As most of you know the CAS sensor is moveable so that you can set base timing.
Would it be safe to assume that the closer my readings in EvoScan are to what the table's are in my tune (Say load 0%ish 1000RPM) means I am more close to what the base timing should be set at?
IE: Load 0, rpm 1000 in my table reads either 6 or 8 for timing advance. At idle my car is at 10-12. Should I rotate the CAS to get that closer to the 6-8 range?
I know I should pick up a timing light and do this the old fashioned way but just for now I'd like it roughly there while I get various other things sorted out on the car.
-Alex
Old Apr 7, 2011 | 04:21 PM
Ceddy's Avatar
You need to use a timing light.
The ecu gets the timing information from the CAS.
So you could be off 20* and the ecu will still log 5* or whatever.
Also the ecu uses timing advance to control idle speed, so you can't go by what the ignition table says at idle.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Dallas J
May 27, 2017 11:53 AM
jb2zero0six5
Aug 3, 2016 12:59 AM
Appauldd
Sep 21, 2015 08:39 AM
smoke3d
Jul 31, 2015 11:23 AM
