What does MIVEC reference for timing?
Old May 25, 2017 | 07:55 AM
Dallas J's Avatar
Veteran: Army
Obviously theirs a fixed CAS for MIVEC and for exhaust cam, but I'm wondering does the MIVEC CAS provide a position relative to itself or in conjunction with feed back from exhaust or crank sensors?
The reason I ask is I see conflicting info on the 4G64 + Mivec setup. Some say set half tooth one way or the other and MIVEC CAS will do the rest (This would assume the CAS references itself and its own location), and some say they adjusted the table one way or the other for the offset (This would assume it references timing to exhaust cam or crank sensor)
Still trying to figure this one out since its not completely straight forward like the exhaust cam is.
Old May 27, 2017 | 09:56 AM
barneyb's Avatar
I don't know anything about MIVEC except what I read in Mitsubishi's advertising. However, it surprises me that some smart cookie doesn't have an Evo running with cam indexers on both cams. It seems like this would be the next big upgrade for the engine providing us with the low rpm torque the engine now lacks.
Old May 27, 2017 | 11:53 AM
ExViTermini's Avatar
You will need to offset the mivec table
rawkus
Mar 24, 2015 06:46 AM
broeli
Jul 3, 2002 05:42 AM
pjal84
Lancer (ES, LS, OZ) Tech Forums
Mar 27, 2002 12:09 AM
