big throttle body
big throttle body
Guys, I fitted big throttle body and the problem is I cannot adjust it, evoscan sees at fully closed condition 16.7% and fully open position 93.33 % . Is there any way I can cure it with ecuflash ?
Are you sure the plate isn't getting caught on the bore somewhere/how? I'd look up in there, rotate it by hand and see if it does open fully. Then if you rule that out, then its your TPS.
FS[Northeast]: Evo 8/9 oem throttle body W/O Sensors
yellowevo82
10
Mar 17, 2017 06:42 PM
MisUnderStood
34
Dec 5, 2016 05:48 AM
