SST MR/SE 1st gear TPS limiter FOUND!
Old Apr 22, 2011 | 01:03 PM
  #31
Evod350z's Avatar
Originally Posted by razorlab
I personally like to manage 1st gear torque with the boost tables. It's much less abrupt and offers more resolution.
You can try setting this table to 100% to remove the TPS limits and then limit your first gear torque with the gear-based boost tables.
This way your also not trying to cram a bunch of boost through 50% throttle plate which I would assume causes a bit of back pressure on the turbo.
Of course, everyone has their different ways.
Limit the first gear torque to what then? What would you recommend?
Old Apr 22, 2011 | 01:25 PM
  #32
RazorLab's Avatar
Depends on your needs.
Old Apr 22, 2011 | 01:55 PM
  #33
fostytou's Avatar
EvoM Community Team
Great work everyone!
Old Apr 22, 2011 | 02:23 PM
  #34
RazorLab's Avatar
Ok first post updated with:
2011 USDM RA 56940007
2009 USDM RA 53600010
2009 EDM SST 54070007
2008 JDM SST 52370024
Old Apr 22, 2011 | 03:44 PM
  #35
willyan1989's Avatar
So quick question, is that the only limit separating SST from its full potential?
Old Apr 22, 2011 | 03:58 PM
  #36
RazorLab's Avatar
No, but it's one of the big ones.
Old Apr 22, 2011 | 03:59 PM
  #37
myersap93's Avatar
What did your tables look like before you modified them?
below is before and after. looked just like table in first post before I modded it. is it possible scaling in XML mod is different? car drove great, no adverse effects noted.
Thanks
either way, this is really cool
Attached Thumbnails SST MR/SE 1st gear TPS limiter FOUND!-sst_1st_geartps_limiter_mr-stock.png   SST MR/SE 1st gear TPS limiter FOUND!-sst_1st_geartps_limiter_mr-modified-usdm-mr.png
Old Apr 22, 2011 | 04:00 PM
  #38
Thank you guys so much for working on the MRs!
What are the other limitations on the SST?
Old Apr 22, 2011 | 04:06 PM
  #39
hotshot1's Avatar
so this does not affect the ra at all? it sounds like the ra tps is already 100%?
Old Apr 22, 2011 | 04:09 PM
  #40
RazorLab's Avatar
Correct. However you can tweak the reverse gear settings as you wish.
Old Apr 22, 2011 | 04:10 PM
  #41
RazorLab's Avatar
Thanks
If you set it back to stock values does it then log correctly?
Old Apr 22, 2011 | 04:25 PM
  #42
NJ Drive's Avatar
Is there any way to enable this programming only in Super Sport mode?
Old Apr 22, 2011 | 06:27 PM
  #43
richardjh's Avatar
Brilliant.
Can I just get a sanity-check on the scaling address (address="6258e") in the first post's XML fragments? Golden's central XML storage site goldenevo.com has these tables added last night, with address="625f0". The example ROM I was looking at: 53600010.
6258e doesn't work on my 53610010, but 625f0 looks perfect.
Ahem, perfect. Apart from the fact that this SST RPM scaling seems to be shared with the t/c Base WGDC and BTEL tables... which I re-scaled while getting my boost targets and error correction fined-tuned!
Oops.
I might just go put those back. If this scaling is shared with one SST table, maybe others are dipping in there too.
Rich
Old Apr 22, 2011 | 08:30 PM
  #44
Golden's Avatar
Yeah the front page is wrong. I may have told Bryan wrong when I first found them.
2009 EDM SST 54070007 and 2009 USDM Ralliart 53600010
- The y-axis RPM addresses should be 625f0 instead of 6258e.
And yes they share the RPM scaling with the Boost tables... Passive / Reactive and others.
Old Apr 22, 2011 | 08:34 PM
  #45
Golden's Avatar
Ahh.. A couple of the RPM scalers are wrong on the front page. I think it's a copy and paste error. Again, might be my bad too. But I thought Bryan double checked my work. (I had other things wrong that he caught. )
2008 JDM Evo MR 52370024 should be 62594
goldenevo.com is fully updated. All SST ROMs have these tables, and I verified every one of them.
