Used Evoscan for the first time! Results!
Old May 7, 2011 | 07:54 PM
prowakeskater's Avatar
did a couple 3rd gear runs and came up with this!
what is boggling me is how I have not installed my lc-1, yet evoscan was able to log AFR? The values were very specific, ranging from 15.4XXXX to 10.7XXXX at redline?
how is that?
Old May 7, 2011 | 08:00 PM
Ian0611's Avatar
Those AFR values are probably the values that the ECU is reading from the fuel map. They are not your true AFRs that the car is running. You need to have a wideband installed in order to properly log AFRs.
Old May 7, 2011 | 08:07 PM
also, I have no idea if I have a walbro. If im at 97.5% duty cycle at redline with no fuel cut and im making these numbers, would that be a fair indication that I do?
Old May 7, 2011 | 09:16 PM
Ian0611's Avatar
Possibly, but I don't necessarily think so... I think it also depends on how much boost you're running and even then it might be hard to tell. One thing you could try is to pull out the bench part of the backseat and listen for a medium-high pitch whine when the car is running. Walbros tend to be a little noisy and are known for the whine.
Old May 7, 2011 | 09:26 PM
hmm, ill try that. Im starting to think I dont, because I think I have hit fuel cut in 2nd before (a couple times, actually) and got violent bucking...
but I also notice that buschur doesnt upgrade fuel till stage 4?
Old May 7, 2011 | 09:32 PM
Ian0611's Avatar
Fuel cut usually has more to do with the amount of boost you're running than the actual components of the fuel system. It's an ECU function that cuts fuel and boost when the load on the engine exceeds a certain limit set in the tune of the ECU to prevent overboosting.
How much boost are you running?
Old May 7, 2011 | 09:33 PM
Im tuned at 21 right now, but ive been pushing around 23
Old May 7, 2011 | 09:37 PM
Ian0611's Avatar
Yeah it's definitely possible that you're hitting fuel cut in the ECU. Do you have Ecuflash and have you learned how to download your ROM yet?
Old May 7, 2011 | 09:39 PM
Just got both programs tonight, I'll try DL my rom tomorrow to see. I feel like im picking it up quickly
Old May 7, 2011 | 09:43 PM
Ian0611's Avatar
Yeah there is a ton of information on this forum about how to tune. I definitely recommend watching the Ecuflash training videos by Recompile and download a copy of Merlins Ecuflash Tuning Guide. Just do a quick Google search and you should be able to find both of them pretty quickly if you haven't already.
Old May 7, 2011 | 09:45 PM
lol, are those the 16 training videos on youtube that are 9+ mins each?
Old May 7, 2011 | 09:51 PM
Ian0611's Avatar
Here's the link for the EP version of the videos... lol There's only 6 of them but they're all about 30-45 minutes long but the information is pretty much invaluable. These are pretty much a requirement if you're going to try to tune your own car.
https://www.evolutionm.net/forums/ec...-ecuflash.html
Old May 7, 2011 | 09:52 PM
Ian0611's Avatar
Here's the link to the tuning guide
http://evoecu.logic.net/mirror/merli...GUIDE-V1.6.pdf
Old May 7, 2011 | 10:02 PM
thanks man! Ill update this with my learnings haha
rxtec
Mar 14, 2016 09:03 AM
Gsxtremedsm
Apr 10, 2013 07:57 PM
RalliArtEvoVIII
May 8, 2005 07:15 PM
NOVA EVO
Mid-Atlantic Region
Oct 11, 2003 08:51 AM
