30psi 0 knock on the 2 step!!!!!!!!
i noticed the same thing with the timing retard when i was setting up other peoples launch maps..
i dont even bother enabling them on my car cause it already makes 20psi just bouncing by itself lol.
I def need a few more psi, Is the correct trend to be pulling timing as the ECU comes down from the rev limit each time(and load)? I can get 10ish, which with 255 star specs leaves a little to be desired.
i have 10-11 psi set by my tuner worked great when the 235 tires where new-ish but now that they are nearly dead I can't even do a launch without them spinning and feeling like I'm driving a FWD again
can't imagine what's the point to get more boost, maybe if you have much larger and stickier tires but then that's the t-case that's going to get it
mrfred
Feb 26, 2022 06:16 PM
evo4mad
May 5, 2015 06:22 PM
