30psi 0 knock on the 2 step!!!!!!!!
Old May 20, 2011 | 10:23 PM
C130flyer's Avatar
Well after about 3 hours of engine, laptop, cell phone, openecu, evoscan and florida mosquito torture I did it.
30psi and ZERO KNOCK on the step with the clutch pushed in AND with perfect seamless transition into regular maps from the launch maps.
Car is EVO 8
Mods: CAI, TBE w/ test pipe, FPred 84mm, MBC, JGS BOV, FIC 1050cc, walboro 255 w/ pressure valve mod, Griffin core intercooler made by ModularTurbo.com, FP oil feed kit, milspec TB seals, exedy twin, TRE helical front diff (shot peened), TRE rear diff upgrade.
Tune: E85 33psi tune by myself and Aaron @ English Racing
I talked with Aaron at great length prior to trying this and after some trial and error we discovered that minimal timing retard netted the best results. I read through the launch maps thread I tried what everybody else was doing and it didn't work for ****.
I attached the EVOscan log file for you guys to see. Notice the speed is zero and the timing advance never drops below -2.
Your thoughts.......???????
here is the log file for evoscan:
https://rapidshare.com/files/1578281...8_18.53.49.csv
Old May 21, 2011 | 12:42 AM
RSMike's Avatar
is this using fuel cut or ign cut? or both?
Old May 21, 2011 | 01:09 AM
C130flyer's Avatar
tephra launch maps so basically the stock 2 step
Old May 21, 2011 | 06:07 AM
Benja's Avatar
Which is a fuel cut based 2-step.
Old May 21, 2011 | 06:08 AM
tephra's Avatar
awesome...
so do the tyres disappear when you launch?
Old May 21, 2011 | 06:10 AM
Benja's Avatar
Lol....molten rubber on the road.
I found anymore than 10psi on street rubber was a waste of time.
Old May 21, 2011 | 06:15 AM
211Ratsbud's Avatar
I've seriously been trying forever to get stove 10 psi wit no knock and I can't get it.. may u post Ur launch maps social can learn what u did ? Def seems like -3 is my limit and is too much.
Old May 21, 2011 | 10:42 AM
justastockevo's Avatar
i'd like to break my transfer case as well, so please post your maps
Old May 21, 2011 | 11:00 AM
06MREvo's Avatar
Originally Posted by tephra
awesome...
^^this! haha, Please post a video of your burnout contest...thanks..
Old May 21, 2011 | 11:07 AM
awdturbo8's Avatar
^^^^^^^ vids please.
Old May 21, 2011 | 01:56 PM
C130flyer's Avatar
I will try to post up a video tonight...
Old May 21, 2011 | 01:58 PM
suby2evo's Avatar
you might as well launch in 2nd
Old May 24, 2011 | 01:51 PM
ant_turbo's Avatar
Bump for video....
Old May 24, 2011 | 02:09 PM
mrboost05's Avatar
post a video i would love to hear the stock ecu at 30 psi it has never sounded as agressive as some of the other evos running aftermarket ecu
Old May 24, 2011 | 02:14 PM
Ian0611's Avatar
In for t-case breaking, tire melting timing maps!!!
