ROM disassembly as raw text file
But without this patch, you can carry zero or negative EC correction into an SST WOT upshift and still see sub-optimal boost control...
Here's a log from a few days before I applied it:
Boost error was -0.7psi right before the shift.
Then, the ECU gets all excited comparing RPM, boost targets, "actual" boost, etc. 0.2 seconds into the upshift, it reckons WTF, BOOST IS 2PSI TOO LOW!
0.2 seconds after that, OH NOES, BOOST IS TOO HIGH!
My little patch shuts down the ECU's first (pointless) response. While there may still be some upward pressure on boost in the second half of the shift, at least there won't be more fuel on the fire from the WGDC error correction system...
Rich
Edited to keep up with your edit!
I'll dig out the OBTR EcuFlash defs you want for 53050009... hopefully tonight.
As for the boost tweak, that's a whole different story. There are good, manageable ways of doing it, and really s**tty ways of doing it. Let me think about that and get back to you.
Rich
Rich
Various defs for 53050009...
As usual, please apply with all due care. Test and log.
I'll send these to Golden...
Rich
Code:
<table name="Reactive Solenoid Max WGDC vs CTS" category="Turbo" address="5a228" type="2D" scaling="WGDuty">
<table name="Coolant Temp" address="5d32a" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="OBTR (Over-Boost Timing Retard)" category="Direct Boost" address="58c74" type="2D" swapxy="true" scaling="Timing">
<table name="Boost Error" address="6261e" type="Y Axis" elements="9" scaling="BoostErrorPsi"/>
</table>
<table name="OBTR Variable for Boost Control 0xC76C -> 0xC712" category="Direct Boost" address="21cc6" type="1D" scaling="Hex16"/>
<table name="OBTR SHLR->SHLR2 0x5201 -> 0x5202" category="Direct Boost" address="21cc8" type="1D" scaling="Hex16"/>
<table name="OBTR Boost Error RAM Address 0xC588 -> 0xC586" category="Direct Boost" address="21cde" type="1D" scaling="Hex16"/>
<table name="OBTR Boost Error RAM Address in Load Error Table 0xC588 -> 0xC586" category="Direct Boost" address="6261a" type="1D" scaling="Hex16"/>
<table name="OBTR (Over-Boost Timing Retard) Load" category="Load Boost" address="58c74" type="2D" swapxy="true" scaling="Timing">
<table name="Load Error" address="6261e" type="Y Axis" elements="9" scaling="LoadError"/>
</table>
Rich
Rich,
Since you've become one of our beloved ROM experts
Golden's 56890009.xml is missing some of the Omni 4 Bar definitions. It appears the MAP tables and a few other things for rescaling are already there. I put together what is missing by duplicating the Load Boost stuff and grabbed the missing scaling factors from the Omni thread but there looks like there are 3 addresses that are needed still for ECU parameters etc.
The addresses in question from the 52680015.xml are:
Also I noticed the address is wrong for this particular definition:
Which reports "0x5141" instead of "0x7f09".
When you're poking around again do you think you could look these up?
Many thanks in advance!!
Golden's 56890009.xml is missing some of the Omni 4 Bar definitions. It appears the MAP tables and a few other things for rescaling are already there. I put together what is missing by duplicating the Load Boost stuff and grabbed the missing scaling factors from the Omni thread but there looks like there are 3 addresses that are needed still for ECU parameters etc. The addresses in question from the 52680015.xml are:
Code:
<table name="Omni4bar #1 0x03B6 -> 0x02FF" address="17d76" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #2 0x0ED8 -> 0x0BFC" address="17da6" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #3 0x0ED8 -> 0x0BFC" address="17dba" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" />
Code:
<table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" address="30648" category="Fuel" type="1D" level="2" scaling="Hex16" />
For Omni4bar, I reckon it's as follows for 56890009/10....
Please note: I wouldn't know an actual Omni4bar if it fell on me!
Also for 56890009/10....
The IPW problem looks one digit should have been a 9 instead of 6. Of course, the wrong one digit can blow up an Ariane 5 rocket. Or your 4B11! Let's fix it...
And make no mistake, XMLs appear on Golden's site thanks to magic. Pay no attention to the chimpanzee behind the curtain, banging his fists on the keyboard.....
Rich
Code:
<table name="Omni4bar #1 0x03B6 -> 0x02FF" address="1a2ee" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #2 0x0ED8 -> 0x0BFC" address="1a31e" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #3 0x0ED8 -> 0x0BFC" address="1a332" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" />
Code:
<table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" address="30948" category="Fuel" type="1D" level="2" scaling="Hex16" />
Rich
Rich
Code:
Code:
Rich
I just noticed you updated the xml so I guess since your the mad scientist behind various XML updates the other 2011 owners would benefit from an Omni section. Here are the other parts if you feel like tossing them in the XML on the site to keep them unitform with Golden's other XML's.
Missing Omni 4 Bar specific scalings:
Code:
<scaling name="Omni4barBoostErrorPsi" units="psi" toexpr="(x-128)*0.2343/4" frexpr="(x*4/0.2343)+128" format="%.1f" min="-6.1" max="6.1" inc="0.1" storagetype="uint16" endian="big" /> <scaling name="Omni4barpsia16" units="psia" toexpr="x*0.2343" frexpr="x/0.2343" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint16" endian="big" /> <scaling name="Omni4barpsia8" units="psia" toexpr="x*0.2343" frexpr="x/0.2343" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint8" endian="big" />
Code:
<table name="Atmospheric Boost (Omni4bar)" address="53488" category="Omni 4 Bar Boost" type="1D" scaling="Omni4barpsia16" /> <table name="Boost Target #1A (High Gear Range) (Omni4bar)" address="58ef1" category="Omni 4 Bar Boost" type="3D" swapxy="true" scaling="Omni4barpsia8"> <table name="Throttle" address="63020" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" /> <table name="RPM" address="62f9e" type="Y Axis" elements="18" scaling="RPM" /> </table> <table name="Boost Target #1B (High Gear Range) (Omni4bar)" address="58f9b" category="Omni 4 Bar Boost" type="3D" swapxy="true" scaling="Omni4barpsia8"> <table name="Throttle" address="63020" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" /> <table name="RPM" address="62f9e" type="Y Axis" elements="18" scaling="RPM" /> </table> <table name="Boost Target #2 (Low Gear Range) (Omni4bar)" address="57465" category="Omni 4 Bar Boost" type="3D" swapxy="true" scaling="Omni4barpsia8"> <table name="Throttle" address="63020" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" /> <table name="RPM" address="62f9e" type="Y Axis" elements="18" scaling="RPM" /> </table> <table name="Target Boost Error Correction (Omni4bar)" address="58d84" category="Omni 4 Bar Boost" type="2D" scaling="OffsetWGDC"> <table name="Boost Error" address="62fc8" type="Y Axis" elements="17" scaling="Omni4barBoostErrorPsi" /> </table> <table name="Omni4bar #1 0x03B6 -> 0x02FF" address="1a2ee" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #2 0x0ED8 -> 0x0BFC" address="1a31e" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="Omni4bar #3 0x0ED8 -> 0x0BFC" address="1a332" category="Omni 4 Bar Boost" type="1D" scaling="Hex16" /> <table name="OBTR (Over-Boost Timing Retard) (Omni4bar)" address="58d20" category="Omni 4 Bar Boost" type="2D" level="3" swapxy="true" scaling="Timing"> <table name="Load Error" address="62ff0" type="Y Axis" elements="9" scaling="Omni4barBoostErrorPsi" /> </table>
And I've avoided the "Omni" OBTR stuff for now, as the "base" OBTR stuff still isn't there. All in good time...
Rich
