Lean at Cold start on Speed Density w/ 9417 rom
Old Jul 22, 2011 | 07:56 AM
92LaserRs's Avatar
Startup IPW matching my Latency table value seemed to work this morning. We'll see if it holds.
Old Jul 22, 2011 | 08:27 AM
l2r99gst's Avatar
Originally Posted by HornstarBU
So....the 2 of you recommended diff things....MAF comp vs coolant and post primer enrich decay. Well, turns out if I adjust one, the other changes too! ! ! Lol, so I guess you are both right. I wasn't able to test this morning, way too late waking up, so I will test when leaving work.
It's the same table. They are just labeled differently in different threads. To get all of the most recent and updated table names and definitions, just read mrfred's advanced fuel control thread.
Post #23 should have the tables for 9653.
Old Mar 24, 2015 | 01:52 PM
bsbllfit7's Avatar
Did you happen to try Evoryders settings? And if so did those work for you? I am experiencing a terrible cold start problem that goes away when the engine warms. Do I just need to adjust the maf comp vs coolant or do I need to do all the tables that Evoryder posted.
Old Mar 24, 2015 | 02:02 PM
02modlanceroz's Avatar
You might want to adjust your post primer enrich decay tables. What rom are you running?
Old Mar 24, 2015 | 02:19 PM
bsbllfit7's Avatar
94171715 currently. Was running 94170715 prior to SD and figured it would help with a smooth conversion to SD.
Old Mar 24, 2015 | 02:25 PM
I'm running 94170015 on my lancer oz, seems to be working pretty decent. I just had to adjust the post primer enrich tables to get the afrs where they need to be. Have to watch not to adjust too far or you'll rev high on startup. I adjusted the post primer enrich tables and post primer enrich decay.
simple_lancer
Oct 14, 2020 02:18 AM
Raceghost
Aug 10, 2018 10:39 PM
W0LF
Sep 15, 2016 08:58 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
Appauldd
Sep 21, 2015 08:39 AM
