Timing in Ecuflash Vs Logged timing.
Are the timing values seen in EcuFlash actual timing values, or are they generic(like AFR values in High Octane fuel map)
I'm getting 0 counts of knock, and logged timing is not correlating with the timing value in the high octane timing map.
I've searched, and all I found was that load could be off, but it would have to be off by about 6 cells and that doesn't seem right.
Current mods, 3inch TBE, k&n cone filter, 2.5inch licp, ETS 3 inch front mount.
how much of a difference are you seeing?
the ecu interpolates so if you hit a cell set to 8 and there is say a 6 next to it you may only get 7 degrees.
if you do a map trace in evoscan you can see what the interpolated value is for a cell hit.
post a screenshot of a map trace.
I figured it would change a little bit between columns, because of the interpolation. I think it's probably a combination between interpolation and Ignition trim vs. Air temp.
I zeroed out the Ignition vs Air temp, I'll have to go out and see if that helps.
Well just went out after zeroing the Ignition trim vs air temp and here are the results.
Only change was the Ignition Vs Air temp. 92*F 52% humidity
Blue graph is today after the ign vs air change. Also, timing is almost dead on with the commanded values, only thing effecting it is interpolation at this point, still zero knock counts!
Indeed, very rich! I'm going to throw another degree of timing at it and see what happens. I'll be interested to see what happens once I get timing set and start leaning it out. It looks like I'll be taking close to a whole point of fuel out in the top of my rpm spectrum. It's seeing 11.0-10.9 at 4750rpm continuing to get to 10.1-10.2 at 7000-7500rpm.
Well here are the current results, leaned the car out a bit. The car seems to be more consistent now, and I think it's time to throw a couple more lbs of boost at it!
Do you mean
Ignition Trim vs Air Temp Above Load?
RPM - 500 1000 1500 2000 2500 3000 3500 4000 4500 5000
% - 70.625 70.625 70.625 70.625 80 80 100 100 100 100
Do you zeroed %?
Thank you for replly.
It looks like I have the same issue
Do you zeroed %?
My guess is he zeroed values in the following table:
<table name="IAT-Compensated Ignition Trim" category="Timing" address="3c8e" type="2D" level="1" scaling="TimingTrim8">
<table name="MAF Air Temp" address="714a" type="Y Axis" elements="8" scaling="Temp"/>
</table>
See the thread for additional details - https://www.evolutionm.net/forums/ec...ing-trims.html
</table>
