2.4 swap ?
Old Jul 31, 2011 | 05:52 AM
catman78's Avatar
2.4 swap ?
Hi guys,
Newb tune? here.
In the process of swapping 2.0 for 2.4 block. Only thing be changed is block. Same cam,injectors, stock ECU, 3 port,etc..,
With the larger displacement what tables I need to adjust regarding?
thanks
Old Aug 2, 2011 | 06:13 AM
catman78's Avatar
Anyone?
Old Aug 3, 2011 | 03:09 PM
mrg72433's Avatar
You may need to tweak your timing. But you will be fine to run the car on current tune, until you can retune. Since you are increasing displacement it changes when you knock, and a bunch of other parameters. I would slo adjust the rev limitir if you changed it. as the 2.4l doesn't like to be revved as high, plus there are no gains on a 2.4l by having a high rev limit
Old Aug 3, 2011 | 03:16 PM
Fast_Freddie's Avatar
Veteran: Navy
You may need to adjust injector scaling, timing, knock tables, fuel table... depends on the car really...
Old Aug 3, 2011 | 04:20 PM
catman78's Avatar
Thanks guys. I know I have to break her in with some pulls @ WG pressure only.
I'll make sure to due some logging before/after swap.
PTE 780's are pretty maxed out.
Current mods are:
cbrd bbk full turbo
kelford 272 cams
ets ic pipes
buschur street fmic
ported exhaust manifold
walbro fuel pump
pte 780cc injectors
perrin intake
grimmspeed bcs
arp headstuds
Synapse Synchronic BOV
Spoolin Up COP
Old Aug 6, 2011 | 07:38 AM
THUB's Avatar
It's pretty likely you'll have to pull a couple degrees of timing, because larger displacement usually needs less, but as long as you aren't SD that should be all, really.
I-5 Evo
Dec 28, 2016 11:58 AM
chevyman89
Jun 1, 2016 08:17 PM
Migsubishi
May 24, 2016 05:26 AM
06mr775
Sep 30, 2015 02:33 PM
UNeK02
Lancer Tranny/Drivetrain Tech
32
Aug 14, 2007 10:00 AM
