New self tuner and maps so far....
Old Aug 16, 2011 | 09:52 AM
soyonara's Avatar
I am very happy to show my maps so far~ Sorry english no to good. How do these look for first time tune.
I want to use tephra because it allow more custom tune. Bigger = better W =)
Mod
injector
exhaust
intake
cam
MAF
intercooler
intercooler pipe
Thanks
Sayonara
Attached Thumbnails New self tuner and maps so far....-fuel-map.jpg   New self tuner and maps so far....-timing-map.jpg
Old Aug 16, 2011 | 09:54 AM
boosted91t's Avatar
Tell us a little about your setup so we can point you in the right direction. They will need some work.
Old Aug 16, 2011 | 09:57 AM
soyonara's Avatar
Sorry edit and added
BigT's Avatar
You run very low timing during spool-up. Is this to maximize spool time? Can you run some of your logs through Virtual Dyno?
Old Aug 16, 2011 | 10:00 AM
soyonara's Avatar
yes I want to make really safe for now no money to build
Old Aug 16, 2011 | 04:24 PM
Raptord's Avatar
How much load are you reaching? If it's anything over 260 you need to get rid of that negative timing.
The timing at spoolup is very low as well, I understand you want to make the tune safe but even then there's no reason for timing that low. Make the transition smoother and you along with your car will be happier.
Old Aug 16, 2011 | 05:53 PM
soyonara's Avatar
Just change from stock map to tephra. I dont think it will go higher than 260
Old Aug 16, 2011 | 05:55 PM
soyonara's Avatar
Does the fuel map look acceptable?
Spec-Ops1's Avatar
To be honest with you, the car will be easier to tune on Tephra V5.10... bigger is not always better...
Old Aug 16, 2011 | 08:55 PM
chetrickerman's Avatar
Veteran: Army
fuel map doesnt look bad as long as you are in the AFR range you want to be. timing though, like raptord said, i think your car will like a little bit more advanced timing at spool up and peak torque. also, in the higher rpms, you want to avoid 2-3* jumps as it will tend to trigger knock.
Old Aug 17, 2011 | 04:20 AM
soyonara's Avatar
Thanks, +1 america very helpful!
Old Aug 17, 2011 | 04:58 AM
longdingydong's Avatar
sounds like you re on the right track good luck
Old Aug 17, 2011 | 08:20 AM
soyonara's Avatar
What rpm, load are you saying low timing ?
Old Aug 17, 2011 | 08:57 AM
Veteran: Army
180-260, and 2000-4250rpms
Old Aug 17, 2011 | 09:20 AM
soyonara's Avatar
thank you. What would you intend for timing that would be safe?
