having trouble with load readings waaay out of whack
Old Aug 17, 2011 | 05:34 PM
GearedUp's Avatar
First of all YES! The car is boost leak tested. 100% and holds 25 psi no problem. Mut2 load goes into the 600 region just free reving while in neutral, also the mut hz reading is a wacky as well so I am assuming this is a scaling issue, I have no idea. I am new to this... I downloaded the tephra rom correct for my vehicle and evo scan already had options for mut load logging, is there something I'm missing here? Thanks in advance.
Old Aug 17, 2011 | 10:08 PM
chetrickerman's Avatar
Veteran: Army
i would check the MAF scaling table that came in the V7 table compared to the one that you were running before
also check the MUT table compared to your old one
