temp scaling C to F
Old Sep 10, 2011 | 03:01 AM
catman78's Avatar
temp scaling C to F
does anyone have the formula for change from C to F.
my base xml only has Celsius values.
Old Sep 10, 2011 | 04:10 AM
todd6027's Avatar
<scaling name="Temp" units="Fahrenheit" toexpr="(9/5)*(x-40)+32" frexpr="(5/9)*(x-32)+40" format="%.0f" min="-30" max="900" inc="1" storagetype="uint16" endian="big"/>
<scaling name="Temp8" units="Fahrenheit" toexpr="(9/5)*(x-40)+32" frexpr="(5/9)*(x-32)+40" format="%.0f" min="-30" max="900" inc="1" storagetype="uint8" endian="big"/>
<scaling name="TempScale" units="Fahrenheit" toexpr="(9/5)*x+32" frexpr="(5/9)*(x-32)" format="%.0f" min="-30" max="900" inc="1" storagetype="int8" endian="big"/>
<scaling name="TempScaleFuel" units="Fahrenheit" toexpr="(9/5)*(x/10)+32" frexpr="(5/9)*(x-32)*10" format="%.0f" min="-30" max="900" inc="1" storagetype="int16" endian="big"/>
Old Sep 10, 2011 | 04:57 AM
catman78's Avatar
excellent, thanks
Old Sep 10, 2011 | 06:03 AM
catman78's Avatar
ok, I'm loosing it. I've changed adding F scaling defs to following files:
evo7base_20081101
TephraMOD-96530706-v7
files location is:
C:\Program Files\OpenECU\EcuFlash\rommetadata\MyDefinitions\m itsubishi\evo
ECUFlash Metadata directory set to
Still seeing Celsius values in ECUFlash. WFT I'm I doing wrong?
I'm running Windows 7, if that helps.
Old Sep 10, 2011 | 06:08 AM
catman78's Avatar
catman78's Avatar
Old Sep 10, 2011 | 08:24 AM
todd6027's Avatar
try change them in the base xml also then save , close ecuflash and open again
Old Sep 10, 2011 | 09:01 AM
catman78's Avatar
tried that, still n/g
post # 6 scaling manager 9530706.
I tried adding new scaling definition, nothing gets save.
Maybe it's a permissions thing with Windows 7. I logged in as administrator though...
New temp scalings I replaced in 9530706 and tephra xml's.
I checked directory path for other xml definitions, could not find any..
Old Sep 10, 2011 | 01:56 PM
ziad's Avatar
check in the virtual store.
C:\Users\USERNAME\AppData\Local\VirtualStore
where username is ur username, u will have rogram files directory and und it open ecu......
thats where ur updated xmls are living currently
Old Sep 10, 2011 | 02:30 PM
catman78's Avatar
spot on mate. works like a charm. That c... s..... gates should have Pancreatic Cancer...
Thanks a million bro...
Old Sep 14, 2011 | 09:45 AM
Gatecrasher R/T's Avatar
Your incompetence is somehow a justifiable reason to with a hideous illness on a man who had little or nothing to do with the problem you're experiencing?
Classy.
Old Sep 14, 2011 | 10:42 PM
codgi's Avatar
Originally Posted by gatecrasher r/t
your incompetence is somehow a justifiable reason to with a hideous illness on a man who had little or nothing to do with the problem you're experiencing?
Classy.
+1. PEBKAC. Truthfully its a bug in the app of itself....config files should never be stored in Program Files.
EVO 4 life
12
Nov 25, 2016 11:37 AM
V.8MR
Oct 7, 2015 02:15 AM
R3VOLUTION
Aug 22, 2015 08:32 PM
Johnny Boy
Nov 21, 2006 05:34 AM
