Advice about fuel pressure and injectors
Old Oct 14, 2011 | 08:09 AM
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Hi guys, I need some advice about what to do in this phase of my project.
My past goal was 350whp at 21psi with my GT3076R, now I bought a PTE DBB 6162 here in the forum, now I want 400whp at low boost, maybe 21-22psi, I know that maybe is not possible but I want 400whp no more, here in my country the fuel is a ****, maybe 89-90 octane, for that reason I do not want to take my motor to the limit, my mind is 400whp with a safe tuning to have fun on the street.
the problem that I have is my injectors, with the GT3076R duty was 85% and now with this new turbo this will change and take my injectors to the limit, I know I need new injectors, but I know that could raise the fuel pressure to reduce the duty of my current injectors. The question is, what changes I make in the setting of my ECU for example if I go up the fuel pressure to 60psi? I need my mix does not change with the excess of gas pressure.
all advice welcome
Old Oct 14, 2011 | 08:28 AM
YaroRS's Avatar
all advice welcome
Get water / methanol injection. This way it almost doesnt matter what quality fuel you use. Also this would lower your injector duty cycle, because methanol substitutes petrol and also you will be able to run lean AFR
mrfred
58
Jan 4, 2016 06:09 PM
Hiboost
26
Dec 30, 2009 04:28 PM
VETTE_50_TH
Mar 25, 2009 08:56 AM
turbodreamz21
82
Apr 14, 2008 05:18 PM
David Buschur
74
Jan 17, 2007 07:09 AM
