Requested Torque/Throttle Ramp Rate Tables
Old Oct 15, 2011 | 07:59 PM
tephra's Avatar
I added in a few more defs.
I also renamed them to "Requested Torque Ramp Rate" as that is more accurate and put them into the Torque category.
Old Oct 16, 2011 | 07:01 AM
itzwolf's Avatar
Any love for 2011 USDM? I'm interested in ROM 56890010.
Old Oct 17, 2011 | 07:31 AM
murlo26's Avatar
Interesting. I might try this out eventually.
Old Oct 17, 2011 | 09:30 AM
fostytou's Avatar
EvoM Community Team
Nice work as always!
Old Oct 17, 2011 | 10:06 AM
RazorLab's Avatar
A note:
These have much more impact (side effects) on the SST cars then on the 5MT.
Just know this when messing with them.
Old Oct 17, 2011 | 10:50 AM
linkbeat's Avatar
Ditto that. I had this done on my old STi to help with daily driving through Engine Load Compensation tables IIRC. Would also love to do this on my 2011.
Old Oct 17, 2011 | 11:41 AM
RazorLab's Avatar
Just in case people didn't know the RPM/MPH breakouts:
Evo X GSR
* 1st gear = 175 rpm/mph
* 2nd gear = 119.3 rpm/mph
* 3rd gear = 88.4 rpm/mph
* 4th gear = 67 rpm/mph
* 5th gear = 46.5 rpm/mph
Evo X MR
* 1st gear = 194.3
* 2nd gear = 125.9
* 3rd gear = 93.2
* 4th gear = 70.3
* 5th gear = 53.6
* 6th gear = 41.2
Old Oct 17, 2011 | 05:43 PM
tephra's Avatar
Originally Posted by razorlab
A note:
Care to elaborate?
Old Oct 17, 2011 | 06:36 PM
RazorLab's Avatar
Originally Posted by tephra
Care to elaborate?
Changes up/downshift characteristics in Auto, etc.
Same with changing requested torque tables.
Old Oct 17, 2011 | 06:37 PM
tephra's Avatar
as in more aggresive shifts (ie clunkier)?
Old Oct 17, 2011 | 06:44 PM
RazorLab's Avatar
More aggressive (or less) up/downshifts. Will "kick-down" much faster (or slower) and at different RPM in Auto. Engine braking changes (clutches take longer or slower to release), etc etc
I've told you a lot of this already David.
Seems like almost all of the torque related tables tweak these things in some way. Probably indirectly.
That 1D table we last talked about in Email (Adjust Offset 2D) for sure changes it. Really bad downshifts (bad rev matching/gearbox meshing) into lower gears with it maxed out.
Old Oct 17, 2011 | 09:59 PM
Bernhard's Avatar
I drive with changed ramp rate maps since about 2 months now and I am quite sure that the cruise control behaves different than before.
Can anyone confirm this?
Old Oct 18, 2011 | 12:52 AM
RS200Z's Avatar
I think the VehicleSpeed address for 2011 EDM should be 62cea instead of 62ce8.
Old Oct 18, 2011 | 01:23 AM
RS200Z's Avatar
If you are using Golden's definition, you can add the following into 56890009.XML as 56890010 inherit from that. Otherwise replace the scaling="Percent255" with just "Percent" as per Tephra's post #1.
Code:
  <table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f853" type="3D" swapxy="true" scaling="Percent255">
    <table name="VehicleSpeed" address="62cea" type="X Axis" elements="6" scaling="VehicleSpeed"/>
  <table name="RevPerMPH" address="63088" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
  </table>
  <table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f81b" type="3D" swapxy="true" scaling="Percent255">
  </table>
  <table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f7e3" type="3D" swapxy="true" scaling="Percent255">
  </table>
  <table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f7ab" type="3D" swapxy="true" scaling="Percent255">
  </table>
Old Oct 18, 2011 | 06:59 AM
Jumperalex's Avatar
So are you saying somewhere there is a way to change the behavior, predictably, of Auto-Normal? Because OMG I could love to tweak that to be a bit more agressive. I'd also like to tweak Auto-Sport to be a tad less agressive. They are just to ofar apart to be useful.
Of course I just default to manual-Sport as a result which is what I should be doing anyway
