Evo 9 ECU issues
Old Oct 28, 2011 | 03:26 PM
Yme's Avatar
Yme
Evo 9 ECU issues
I have an evo 9 and last night my friend tried to flash my car but was unable to do so.
It was giving him the "Interface closed" error code. We tried it on his car and everything works just fine.
We disconnected the battery, etc , still no luck.
Any ideas?
Old Oct 28, 2011 | 03:33 PM
JohnBradley's Avatar
ECU is locked possibly, the voltage was low in your car, something in the OBD plug on the car side of the harness is messed up. Will it turn the car off while its running? If it wont even do that then the harness has an issue somehow.
Old Oct 28, 2011 | 04:49 PM
Yme's Avatar
Yme
we checked the ECU and it's not locked. The voltage is a possibility, gonna replace the battery and see if it'll work.
I forgot to mention that at first my friend was able to log the car but not read and write, after that he wasn't able to do anything.
thanks
Old Oct 28, 2011 | 05:09 PM
vmrevo9's Avatar
Veteran: Air Force
Try starting the car and let it run for a few minutes than try and read the ecu
Old Oct 28, 2011 | 05:24 PM
Yme's Avatar
Yme
did that, still same error
Old Oct 29, 2011 | 05:44 AM
Yme's Avatar
Yme
Aaron, no it didn't turn the car off while its running. Where can i get a harness?
Thanks
cerevo
May 5, 2017 03:02 PM
BPAuto
Aug 9, 2016 02:03 PM
StarCharlie
Lancer Engine Tech
Nov 25, 2015 01:41 PM
mmarine9
Jul 17, 2015 02:39 PM
audiofan
Sep 26, 2014 05:57 AM
