Knock Algorithm (and the Low/High Oct table delta)
Old Sep 14, 2012 | 07:24 PM
  #31
chetrickerman's Avatar
Veteran: Army
Originally Posted by fostytou
I think you are doing it wrong.... and possibly going to blow up your car. Maybe you should contact COBB about the maps being incorrect or check to see if you are using the correct OTS map...
Tephra and I have had this conversation a few times, a lot of the time the code says one thing, but ECU does something else. In this case the delta between the two timing maps multiplied by .35 isnt a limit. There isnt a limit on how much timing the ECU can pull no matter how far apart or close together the two timing maps are.
Old Sep 14, 2012 | 08:15 PM
  #32
sgoodwin1's Avatar
I contacted Cobb and I'm using the correct ots map I have all Cobb parts and I'm using the stage 2 93 v108 map with their exact mods, Cobb isn't very helpful btw.
Old Sep 15, 2012 | 09:38 AM
  #33
sgoodwin1's Avatar
Yeah I have now fixed the knock issue correctly but it helped to set them the same to figure it out
tephra
Apr 22, 2026 11:03 AM
nj1266
Jan 25, 2026 01:43 AM
domyz
Jul 27, 2022 11:54 AM
tephra
Sep 13, 2021 01:07 AM
tephra
14
Aug 23, 2010 08:27 AM
