Removing stock Boost control selenoid, ecu periphery bits change
Old Nov 3, 2011 | 07:01 AM
kartectuning's Avatar
Hi Guys
If I remove the twin stock BCS i will trigger a p0243 CEL, tried a 33ohm resistors in place to complete the check circuit, but I still get the Code
Does anyone know if changing the ecu periphery 3, bit 4 from 0 to 1 will stop this ecu test circuit and wont have any colateral tuning issues on timing, fuel tables etc etc
Rom is a SADM 88580015 evo IX, the bit 4 is 0 from stock hex file
Using ecuflash 1.43
Thanks for the advance
Old Nov 4, 2011 | 10:54 PM
JohnBradley's Avatar
periphery 2, set to 0001. That whole periphery is all BS so turn them all off except the last one I do it in hex so I am not sure what bit it is.
Old Nov 5, 2011 | 05:53 AM
last one from top to bottom on ecuflash? bit 15 to leave it alone? or bit 0? last one could be different from the view we choose to start from
thank a lot
Old Nov 5, 2011 | 08:55 AM
when you are using the bits, it would be the bottom one stays set at 1. Turn all the others off ( to 0)
Old Nov 5, 2011 | 05:09 PM
thanks!
Biggiesacks
Oct 13, 2016 02:37 PM
Appauldd
Sep 21, 2015 08:39 AM
92 GSR-4
May 9, 2014 10:08 AM
el.guerrero
Nov 3, 2012 04:25 AM
r4p.t0x
Aug 5, 2012 04:26 AM
