FIC1100: Mid fuel trims stay zero?
Old Nov 27, 2011 | 02:34 PM
KOOLER's Avatar
OK, P&P did not work. Using 1.3 cable produces the same results - low trims are logged and mid trims are staying zero ( F%^$%^$%^
Old Nov 28, 2011 | 08:00 AM
KOOLER's Avatar
OK, little update... It LOOKS LIKE if scaling is deadly wrong (short trims are -12.5% and it's a maximum I beleive) then mid trims are not going to chage at all. Now I;m reverted back to 1083 scaling and listed latencies and have short trim of -7.2% and mid trim of -0.75%. Should I decrease latencies now or what?
Old Dec 4, 2011 | 06:45 PM
dude's Avatar
Yes, a negative fuel trim indicates that the ecu is decreasing fuel, therefore you should decrease your 14v latency only and leave the others alone. I would do it the smallest increment ecuflash will allow (decrement decimal value until the next lower value is changed in the 2d table)
Disconnect neg batt terminal and step on brake pedal to reset ECU. Start car and allow to get to operating temp (trims will all be zero). Shut car off, restart, trims will now update, and let idle for 4 updates of LTFT Low, then cruise for 4 updates of LTFT mid.
Old Dec 5, 2011 | 01:23 PM
Boosted Tuning's Avatar
^ Everything he said
Old Dec 6, 2011 | 12:36 PM
KOOLER's Avatar
OK, one question so far - if I have Evo IX do I really need to disconnect the batt?
Old Dec 6, 2011 | 12:44 PM
CurseDSM's Avatar
I mentioned to do that in the 10th post.
Old Dec 6, 2011 | 01:32 PM
KOOLER's Avatar
You guys have VIII and I have IX... OK, I'll do it in any case
Old Dec 6, 2011 | 02:56 PM
vd's Avatar
vd
Could you please tell a bit more about why do we need to follow the reset procedure?
The question is due to the fact that on my EvoIX (EDM, ROM 88580714, stock ROM 88840016) fuel trims are being reset every time I reflash the ECU and after that trims are routinely updated during normal idling or cruise. Is there any particular reason to follow the above-described procedure?
Thanks in advance to those knowledgeable.
Old Dec 6, 2011 | 03:02 PM
CurseDSM's Avatar
Answer is because your resetting all the known values that effect the way the trims work. Even if they are rest the car still keeps whatever settings it has therefor nothing is being changed.
Old Dec 6, 2011 | 03:14 PM
KOOLER's Avatar
Did everything like dude said. Everything is fine except it take a while to start updating low trims, they stabilized at -5.27% but mid trims never came out of 0%. More then an hour driving on a highway ~100 km/h. Any ideas why it could be?
Old Dec 6, 2011 | 03:23 PM
CurseDSM's Avatar
Is your airflow hz above 120hz? If not its not gonna change.
Old Dec 6, 2011 | 03:35 PM
KOOLER's Avatar
Yes of course! Around 200 Hz.
Old Dec 6, 2011 | 03:50 PM
CurseDSM's Avatar
Ok didn't know what that was in mph for hz sorry.
Fast_Freddie
Oct 30, 2023 01:56 AM
Toekneee!
Aug 24, 2015 07:01 PM
mrfred
Apr 17, 2015 09:38 AM
babaz7
Jul 6, 2012 06:35 AM
