MAF comp. table
Old Dec 4, 2011 | 08:40 AM
stunt2's Avatar
MAF comp. table
maby a very noobish question, but what exactly does MAF compensation table do, what does it compensate ? what happens if rising or lowering these values ?
what is this table for, if there's already MAF scaling table, to make changes in air flow readings
Uploaded with ImageShack.us
Old Dec 4, 2011 | 11:49 PM
stunt2's Avatar
any input is appritiated
Old Dec 5, 2011 | 06:02 AM
charlie.tunah's Avatar
The MAF Comp table is sort of a VE table. Changes here only change fueling. For 2D SD, Ive only used the Rpm VE table and the MAF Comp table. RPM VE being rpm dependant, MAF Comp being airflow dependent.
MAF Scaling table changes how the MAF reads the airflow and also changes the way load is calculated. (Im pretty sure that's accurate) I do know that when only trying to adjust fueling, you dont want to mess with the scaling table.
Old Dec 5, 2011 | 08:38 AM
burgers22's Avatar
MAF comp is like a trim, you can use it to correct for a new air filter. As mentioned it's better to adjust the comp rather than the MAF scaling, however extending the MAF scaling and adjusting the upper part of the table is a good way to get sane load levels on a big turbo with MAF
Old Dec 5, 2011 | 09:35 AM
stunt2's Avatar
thanks guys
so, tweaking with compensation table changes the fueling right ?
and which way, dicreasing it leans and increasing richens the afr ?
also, by how much to increase/dicrease the value to make change say in 1 (one) point of afr ? from 13.5 to 14.5 for egsample
Old Dec 5, 2011 | 09:39 AM
Raptord's Avatar
Increasing the values causes the sensor to read a greater quantity of air, so it will richen the mixture.
Old Dec 5, 2011 | 01:15 PM
Boosted Tuning's Avatar
Also, it shouldn't read as units. that was the old scaling. Now most scale it as percentage.
way2qik
Jul 26, 2014 06:04 PM
MACKLIN
Mar 10, 2013 07:27 PM
sith_killer_99
South Region
Sep 8, 2012 03:50 PM
VGergo
Dec 9, 2010 04:24 AM
