NEED HELP ASAP! Just tried to change idle and now car won't start!
Old Dec 17, 2011 | 10:51 AM
darkside4G63's Avatar
Yesterday I went into ecuflash to change up idle a little and as the reflash was running it popped up an error in the middle of the process. I swapped USBs and flashed it again and this time it went through. I tried to start the car and it just cranks. I flashed in other known good maps with not errors and still the same thing. I have a mini battery so I thought that low voltage might be an issue so I left it on a battery tender. Tried again this morning and it still just cranks even on several different good maps. I disconnected the battery for over a hour, hooked it back up, went back and flashed it again and still It just cranks. Please help. This is my main vehicle and I'm really in a bind. Thanks in advance
Old Dec 17, 2011 | 12:13 PM
Evoloved's Avatar
Maybe your immobilizer code got left out I know its a dumb thought but maybe
Old Dec 17, 2011 | 01:26 PM
Hell I'll try anything at this point. I know you can turn the immobilizer off in the periphery settings. Anyone know which one it is?
Old Dec 17, 2011 | 01:43 PM
Spec-Ops1's Avatar
Check your ignition fuses the one by the battery and under the dash...
Old Dec 18, 2011 | 09:11 AM
Evoloved's Avatar
periphery settings 0 FAA bit 3
