ecuflash/speed density help
Old Jan 4, 2012 | 08:04 PM
DormantBeast's Avatar
Ok guys im about to rip my hair out trying to figure out this darn headache. My ecuflash wont open up my SD roms without missing info. I alredy searched and ya a lot of stuff comes up but with it being so late in the game idk which updates are the most current and if theu interfere with one another ive uninstalled ecuflash like 5-7 times trying different combinations of patches and updates... Can some one pls so i can get the correct files needed to open a SD tune in ecuflash for a evo 9 internal id is 88592715. Pls if possible show me all the needed files to operate smoothly
Old Jan 4, 2012 | 10:35 PM
Resi's Avatar
posted by phenom:
9653X706
8859X715
Replace the X above with the number below:
0 = MAF
1 = Speed Density
2 = DMA (Live Map)
3 = DMA (Live Map) + Speed Density
According to this, you are not currently running a speed density rom, hence no speed density tables will be displayed. You will need to go to the Live Map thread and download the appropriate xml file for your rom, or change to the 88593715 if you wish to run live map and speed density.
Alternatively, your tuner may have purposely changed the rom id from 88591715 to make it more difficult for you to open/adjust the rom.
Old Jan 5, 2012 | 09:14 AM
211Ratsbud's Avatar
Which are you trying to run, 2d or 3d?
Old Jan 5, 2012 | 09:19 AM
211Ratsbud's Avatar
Btw 88592715 is also a 3d sd rom
Old Jan 5, 2012 | 09:22 AM
3d more then likely since its newer, but i wouldnt mind either or to be honest
Old Jan 5, 2012 | 09:25 AM
211Ratsbud's Avatar
Where did you add the xml to?
Old Jan 5, 2012 | 09:28 AM
umm which xml? lol I added some to the xml file I added to ecuflash to read the tephra roms. I add them inside the xml with notepad. Im at work so dont have the files in front of me or I could be more specific. But Ive downloaded a lot of patches and updates but cant seem to get them to work with SD
Old Jan 5, 2012 | 01:35 PM
211Ratsbud's Avatar
Ill email you a folder named evo. Back up your folder named evo, remove it. Then paste mine in there. I use 88590715 v7 maf 88592715 3dsd . Those are pretty complete and will get you on track.. if you want it.
Old Jan 5, 2012 | 01:42 PM
thank you very much^^ I'll do that after work today.
Old Jan 5, 2012 | 07:38 PM
ok it looks like I need to change the inherits from evo9base_20081101 to TephraMOD-88590715-v7... Ive been trying but cant seem to get that switched over anyone have an idea on how to do this? I seem to be able to get everything working fine on my laptop but my desktop isnt and ive copied my rommetadata folder from the working laptop to my desktop but that didnt work? ideas??
Old Jan 6, 2012 | 03:28 PM
211Ratsbud's Avatar
Man nothing should have to be altered like that to work.
Old Jan 18, 2012 | 02:42 PM
DubsE46's Avatar
So I've been having some issues switching to SD, my idles are off. cold start doesn't seem to get enough fuel so I have to hold the gas down a bit for it to warm up.
Anyone have a base map that will help me get my evo8 running, enough too drive it to a shop.
I don't think I set it up right or can I email my map to someone. To let me know what's wrong
Old Jan 18, 2012 | 04:59 PM
evo420's Avatar
hey man there you are, this is amaev05
Old Jan 18, 2012 | 05:09 PM
evo420's Avatar
hey i would recommend hitting up one of the remote tuners to sat you up, tscompusa seems pretty cool and knowledgeable, this will help you learn to tune your car,
Old Jan 18, 2012 | 05:15 PM
evo420's Avatar
unless your not in a rush.......... downloading...........
Hic
Jun 14, 2016 09:28 AM
fireroasted
Aug 15, 2012 05:57 AM
mitsevolution
10
Jun 7, 2011 07:28 PM
EvOSean06
May 26, 2011 11:58 PM
Dochka
Feb 28, 2011 04:01 PM
