fuel pump low/high voltage transition table
Old Jan 26, 2012 | 07:15 AM
  #46
justastockevo's Avatar
Originally Posted by mrfred
Its for Evo 9.
well, then perhaps i don't know something... RequestID="238085EB" isn't it canbus request and not mut ii? i always assumed that mutii requests are 2 bytes, like RequestID="ff"
Old Jan 26, 2012 | 07:35 AM
  #47
mrfred's Avatar
Ah, now that was inadvertently Evo 10. Its now Evo 7-9. Thanks.
Old Jan 26, 2012 | 07:55 AM
  #48
thanks mr fred, very useful post
Old Jan 26, 2012 | 09:59 PM
  #49
HyperDisorder's Avatar
Originally Posted by EvocentriK
Wow good find!
Could you please find the tables in 96260009 for me?
I've figured that the load location is 420E, but I'm still a bit noob with IDA, so haven't figured out how to find the RPM axis location. I could guess, or assume that the RPM axis locations already defined in my xml for other things are correct, but that's just not right!
Old Jan 28, 2012 | 12:43 PM
  #50
Jack_of_Trades's Avatar
So I have an Evo 8 here and I always wondered why the car gets stuck in open loop after starting sometimes. Well, I have the rear seat out so I could hear that the fuel pump was at full battery voltage and the AFR was VERY lean in open loop (18-19 AFR).
After a few minutes, the car switched back to low battery voltage at the pump and closed loop operation returned and AFR was back to 14.7 and fuel trims are close to zero.
So I guess the ECT and IAT conditions have something to do with it but it seemed odd that the AFR would be leaner with higher battery voltage but would have perfect fuel trims when closed loop and low battery voltage occured.
Thoughts?
-Jamie
Old Jan 28, 2012 | 02:39 PM
  #51
mrfred's Avatar
Coolant temp and IAT both have to be pretty high to trip the longer delay to going to low voltage. Those timers could be tied to other algorithms in the ECU. I can look some time.
Old Jan 28, 2012 | 05:36 PM
  #52
What else forces the ecu to stay in closed loop after startup besides the TPS and engine load openloop tables? If I cracked the TPS by less than 1%, it immediately goes into closed loop.
Old Jan 29, 2012 | 03:28 PM
  #53
mrfred's Avatar
There are a bunch of factors that go into deciding whether the ECU puts the engine in closed loop. Its way more than the the throttle and load tables.
Old Jan 30, 2012 | 07:11 AM
  #54
EvocentriK's Avatar
Well that's something! Most guys in Oz with 8's run 9626 which is why I was after it.
Maybe mrfred or someone can help sort it for us.
Old Feb 15, 2012 | 11:53 PM
  #55
Acree's Avatar
Originally Posted by JohnBradley
Used this on Martin's car the other day to help time the transition to the second pump. Worked very good.
Aaron
Can you clarify this? I'm assuming second pump means you're running dual walbros in parallel. If this is the case, how would delaying the time that the first pump goes from low to high voltage help out smoothness when the second pump kicks on?
-Acree
Old Nov 5, 2012 | 07:08 PM
  #56
ExViTermini's Avatar
So, is there a way to make the ECU ignore the IAT and ECT inputs so that the hi switch isn't thrown upon startup? Only have it thrown when above say 80% throttle and whatever load.
Would be nice to make a dual pump control with this...
Old Nov 6, 2012 | 06:59 PM
  #57
mrfred's Avatar
Yes, it can be done, but the low/full voltage switch on the primary pump is needed in order to avoid overrun at idle. Even a Walbro 255 running at full voltage can overrun the fpr at idle.
Old Nov 6, 2012 | 07:38 PM
  #58
Yea....I noticed haha. Had my trims within 3%, hardwired the pump, now they are like -10-12 lol. Little tweaking here and there getting it back to normal.
How can we get TPS % incorporated into this, or is that possible? Sorry, I know nothing about disassembly or programming
Old Jul 29, 2014 | 11:01 AM
  #59
criptballer's Avatar
bringing this back from the grave, what about for rom ID 88590715 and all the tephra V7 maps?
how come this isn't on there already? do you guys know of a thread compiling all tables not found in V7?
Old Jul 29, 2014 | 03:45 PM
  #60
mrfred's Avatar
The 88590015 table also works for 88590715. Its up to you to add it to your definitions.
