Injector shut-off map
Old Feb 29, 2012 | 10:59 PM
  #31
CDrinkH2O's Avatar
Originally Posted by cdrinkh2o
And - thanks, that helps mate. I'm using IDA PRO 6.1 to mark up the 96530706 ROM and I can now compare it to 9055001 & 8997010
and run a pattern match search for these same tables. I will post back the xml if I find a match in 9653XXX6.
Can you can test the effect of changing these tablesa nd post back what you find?
Found a match in 96530706:
Code:
	!!!!! CORRECTION - This table is incorrectly defined. It is actually Air Density Compensation for Load And IPW.
<table name="Decel Fuel Cut Resume Enrich" category="Global Fuel Settings" address="38fa" type="2D" level="2" scaling="EnrichmentAdj">
	<table name="Engine Temp" address="69d8" type="X Axis" elements="9" scaling="Temp"/>
	</table>
	<table name="Decel Fuel Cut RPM Offset" category="Global Fuel Settings" address="36dc" type="2D" level="2" scaling="RPM8">
	<table name="Engine Temp" address="69be" type="X Axis" elements="8" scaling="Temp"/>
	</table>
I'm sure the Decel Fuel Cut RPM Offset is right. I'm not sure the Decel Fuel Cut Resume Enrich is correct because the RPM settings are way different than the Evo 7. I'm going to test and see if these make any difference to the fuel cut off on lift. Will post back with results.
Old Feb 29, 2012 | 11:38 PM
  #32
merlin.oz's Avatar
is not a very accurate description of this table, it is the RPM at which decel Fuel-Cut is cancelled and fueling resumes.
Old Mar 1, 2012 | 11:00 AM
  #33
And's Avatar
And
yeah no probs, just let me know when you have some tables you want me to try out
Andy
Old Sep 19, 2012 | 06:59 PM
  #34
wizzo 8's Avatar
Does tephra have a table for this? If so which one is it? If Im coasting at lets say 5k rpm and let off the gas and coast to idle the injectors kick on before I get to idle. The eng starts rocking the car because it kicks on and off. What can I do to control this?
Old Sep 21, 2012 | 04:59 AM
  #35
211Ratsbud's Avatar
Similar problem with my cams, idling down is smooth but at a certain point fueling resumes and bucks the car
Old Sep 21, 2012 | 07:17 PM
  #36
CDrinkH2O's Avatar
Yes V7 has the table. In 9653XXXX it's a 2D table called Decel Fuel Cut Resume RPM
Code:
<table name="Decel Fuel Cut Resume RPM" category="Global Fuel Settings" address="36dc" type="2D" level="2" scaling="RPM8">
 </table>
Old Sep 21, 2012 | 07:19 PM
  #37
CDrinkH2O's Avatar
Use Decel Fuel Cut Resume RPM. I lowered mine to 100 RPM above my idle and it reduced the bucking.
Old Sep 21, 2012 | 07:30 PM
  #38
211Ratsbud's Avatar
Originally Posted by Acree
Any chance for the 88590715 rom?
-Acree
?? Any def for this ??
Old Sep 21, 2012 | 07:44 PM
  #39
CDrinkH2O's Avatar
Let me take a peek Acree and see if I can find the same table in 88590715. If not you'll have to change to 9653XXXX .
Old Sep 21, 2012 | 08:01 PM
  #40
Ian0611's Avatar
Code:
 </table>
Does this table exist for V7 94170715?
Old Sep 21, 2012 | 10:32 PM
  #41
CDrinkH2O's Avatar
Yep it's there in 88590715. It's the only occurance of the byte string in the whole ROM so its a good bet that it's correct. Check it all the same and post up if it works.
Code:
 <table name="Decel Fuel Cut Resume RPM" category="Global Fuel Settings" address="30FE" type="2D" scaling="RPM8">
  <table name="Engine Temp" address="6fde" type="X Axis" elements="8" scaling="Temp"/>
 </table>
Old Sep 21, 2012 | 10:37 PM
  #42
CDrinkH2O's Avatar
Ian I would look but don't have the 94170715.xml for it. PM me and let's see if you can get it over to me.
Old Sep 21, 2012 | 11:30 PM
  #43
CDrinkH2O's Avatar
Yep it's there. There are a few temp axes with the same data in 94170715 so I'm not completely sure that the temp axis address is correct. I am sure that the RPM data is correct though. Check it out and post up if it works for you.
Code:
  <table name="Engine Temp" address="67a2" type="X Axis" elements="8" scaling="Temp"/>
 </table>
Old Sep 22, 2012 | 04:10 PM
  #44
wizzo 8's Avatar
I dont have this table. I have Decel fuel cut delay #1, 2, 3 and 4. They are all set the same but it doesnt have an rpm axis. It has load 10-70 and units 7-55.
I have ecu id 96530706
Old Sep 22, 2012 | 05:52 PM
  #45
211Ratsbud's Avatar
Ok, i have added, deleted added and added again, added to other XML and I cannot get this map to show.. Where should this table show up at? I didnt see it any where, especialy in global fuel
Code:
 </table>
