Injector shut-off map
Old Sep 23, 2012 | 12:20 PM
  #46
CDrinkH2O's Avatar
Originally Posted by wizzo 8
I dont have this table. I have Decel fuel cut delay #1, 2, 3 and 4. They are all set the same but it doesnt have an rpm axis. It has load 10-70 and units 7-55.
I have ecu id 96530706
Error correction - I was wrong about the Decel Fuel Cut Resume RPM table. I just found it was mis-identified for this ROM.
Old Sep 23, 2012 | 12:34 PM
  #47
CDrinkH2O's Avatar
Deleted
Old Sep 23, 2012 | 02:48 PM
  #48
07EvoIX's Avatar
does anyone have the address for the ADM 8858 ROMs please?
cheers
Old Sep 23, 2012 | 02:55 PM
  #49
211Ratsbud's Avatar
cheers
Sas settings may be invaded there?
Old Sep 24, 2012 | 10:09 PM
  #50
CDrinkH2O's Avatar
AUDM 8858 Decel Fuel Cut Resume RPM
cheers
nvm
Old Sep 24, 2012 | 10:29 PM
  #51
CDrinkH2O's Avatar
Not sure what you are asking here 211ratsbud ... Can you be a little les cryptic?
Old Sep 25, 2012 | 01:22 AM
  #52
07EvoIX's Avatar
thanks mate, i get the same results as you have posted.
cheers
Old Sep 25, 2012 | 04:52 AM
  #53
211Ratsbud's Avatar
Sas doesn't cut fuel on decel so I was wondering of the sas settings may conflict this map. Obviously not.
I will say fr sure that me switching to 8858 has treated me very well and is many times smoother than my USDM 8859
I'm familiar enough with XML modifying to compile and add Xmls for many other things over time ie iscv disassembly and this map is one that I cannot get to work.
Old Sep 25, 2012 | 11:35 AM
  #54
And's Avatar
And
i think this could be the address for the 9626 rom
Code:
<table name="Decel Fuel Cut Resume RPM" category="Global Fuel Settings" address="36dc" type="2D" level="2" scaling="RPM8">
    <table name="Engine Temp" address="5c60" type="X Axis" elements="8" scaling="Temp"/>
 </table>
if some one wants to check Andy
Old Oct 2, 2012 | 04:35 PM
  #55
wizzo 8's Avatar
You need to update your 96530706.xml file (usually found in c:\program_files\OpenECU\EcuFlash\rommetadata\mits ubishi\evo) with at least the code below.
Code:
  <table name="Engine Temp" address="69be" type="X Axis" elements="8" scaling="Temp"/>
 </table>
If you use EvoScan to reflash you will also need to copy it to the same folder you keep your ROMs in.
I havent updated an xml file in a while. Do I add this to the base file or the 96530006xml file? I tried adding it to the 96530006xml and the table didnt show up for me in ECU flash. I have the Tephra mod also.
Old Oct 2, 2012 | 05:04 PM
  #56
ToddRhodes's Avatar
Ok so I got this to show up in ECUFlash, now it's a matter of understanding the point. Am I correct in assuming this table, Decel Fuel Cut Resume, is not meant to reduce the "rich condition after throttle lift" but rather where the engine starts to add fuel under decel which can prevent bucking? Just making sure I'm on the right page here, I unfortunately am nowhere near as familiar with these things as most in this thread.
Old Oct 3, 2012 | 05:33 PM
  #57
CDrinkH2O's Avatar
You have understood the purpose of this table correctly. I dont believe there is a way to control fuel cut on decel for this ROM.
Old Oct 3, 2012 | 05:34 PM
  #58
CDrinkH2O's Avatar
Deleted
Old Oct 3, 2012 | 06:45 PM
  #59
wizzo 8's Avatar
Read what I said again.
Yea I got it but its not working for me. Oh well Ill just deal with it for now. Thanks for trying to help
Old Oct 4, 2012 | 07:32 AM
  #60
CDrinkH2O's Avatar
Yea I got it but its not working for me. Oh well IlL just deal with it for now. Thanks for trying to help
Pm me and let's take this off thread
