evoscan ?
Old Feb 13, 2012 | 06:58 PM
Blue_05EVO's Avatar
Just 3 pulls no knock anywhere ......injector cycle highest was 92
Boost was 22-23
Timing was 4- 13
But mu WIDEBAND says im running 12.0 at wot
And the ECU afr says 10.1 at
peak
And my tps only goes to 99.6 lol...
Srry my phone wont let me upload my log and it is my Internet
Old Feb 13, 2012 | 07:01 PM
CurseDSM's Avatar
Sounds like you need to tell evoscan what wideband you have.
Old Feb 13, 2012 | 07:06 PM
Blue_05EVO's Avatar
My WIDEBAND is being eyeballed (I know bad) but the aux connect got burnt by a friend .....
Lc1 by the way
Old Feb 13, 2012 | 07:09 PM
CurseDSM's Avatar
I would worry about getting that fixed next, that way you can log your true wideband reading in evoscan.
Old Feb 13, 2012 | 07:12 PM
Raptord's Avatar
The real AFR will NOT match what it says in your map. The values in the map are just numbers, not the actual values you'll get. I would richen the AFR to mid 11's for pump gas but other than that sounds like the tune is decent.
Old Feb 13, 2012 | 07:16 PM
CurseDSM's Avatar
Right he is talking about from his guage to evoscan not matching up.
Old Feb 13, 2012 | 07:35 PM
Raptord's Avatar
Boost was 22-23
Timing was 4- 13
peak
That's not how I'm understanding his post; his wideband reads 12 and his "ECU afr", which I'm guessing to be his fuel map, says 10.1.
Old Feb 13, 2012 | 07:36 PM
Blue_05EVO's Avatar
My next thing is to re watch how to do the mut table for 2 byte load video... bc my mut 2 byte load in evoscan now says 2000 some....
So after I figure that out I will go in and look at my high octane table and richen up that area slightly
My main last question is a little off topic, but my hillman is in my opinion reliable however I turned it down quite a bit and im still boosting to 24 and dropping 21...almost like it wont drop any further ....thinking a loose vacation.line pre mbc ....what do you guys think??
I will know for sure bc I am installing an injen licp this weekend
Old Feb 13, 2012 | 07:49 PM
Blue_05EVO's Avatar
Evoscan afr not ecuflash table
Old Feb 13, 2012 | 07:50 PM
CurseDSM's Avatar
Sorry bout that your correct I misread.
Old Feb 13, 2012 | 08:03 PM
Raptord's Avatar
So your wideband was reading ~12 at WOT but evoscan was logging 10.1? Looks like either the formula is off or the wrong wideband is selected.
Np mate, but looks like you were right in the end.
Old Feb 13, 2012 | 08:13 PM
CurseDSM's Avatar
It is all good I just didn't want to mislead anyone.
Old Feb 13, 2012 | 08:19 PM
Blue_05EVO's Avatar
I was telling curedsm that.my aux from mt WIDEBAND is burnt so its in my list of electrical to do fixes....
So I guess evoscan is just using the factory sensor and showing me what it is reading I just didn't think it would be that far off
Old Feb 13, 2012 | 11:22 PM
codgi's Avatar
The factory sensor is a narrowband and yes its way off once you get into WOT situations.
Old Feb 13, 2012 | 11:42 PM
Blue_05EVO's Avatar
Yea even cruising it says 14.7 but my WIDEBAND says 14.2-3
