evo 9 alternate maps not working
Old Mar 10, 2012 | 08:07 AM
alexui90's Avatar
i tried to switch to alt maps but ics lamp is not flashing and alt maps are not acivate at all...any ideas? tephra mod v5 rom id 88570008
Old Mar 11, 2012 | 05:07 AM
todd6027's Avatar
In the rom find tephra mod options section then
enable alt maps master (set to 2)
restore ics state on ign (set to 1)
flash ics when on alt map (set to 1)
then flash it back
Old Mar 12, 2012 | 01:23 AM
alexui90's Avatar
i've done them exept restore ics state on ignition..whats it mean?
Old Mar 12, 2012 | 03:11 AM
Benja's Avatar
That if you are on your alt map when you shut the car down. It stays on the alt map next time you turn it on.
Old Mar 12, 2012 | 05:05 AM
todd6027's Avatar
in a nutshell
Old Mar 12, 2012 | 02:42 PM
07EvoIX's Avatar
are you pressing the ICS button for as long as it is set, eg, 3 seconds?
cheers
Old Mar 16, 2012 | 06:20 PM
alexui90's Avatar
yes..even more..
Old Mar 25, 2012 | 05:11 AM
alexui90's Avatar
any ideas ??
Old Mar 25, 2012 | 10:02 AM
Vigman's Avatar
-Are you trying to change your map with the car running? (remember that Load has to be low to authorize map switching)
-You can intent this in order to see if the map is really switching in the case it is just a output lighting failure...Try to set your injector size 50% smaller on the alt map and check idle AFR; It should be o lot richer when you switch on Alt maps.
Old Mar 25, 2012 | 02:20 PM
07EvoIX's Avatar
you might want to try PM tephra and ask directly
cheers
Old May 15, 2012 | 10:24 PM
alexui90's Avatar
still not working =[
Raceghost
Nov 16, 2016 08:53 PM
211Ratsbud
Jul 31, 2012 04:55 PM
hearnoevo
Mar 22, 2012 09:08 PM
jamiestsi
Feb 29, 2012 02:31 PM
jdmevo123
May 1, 2010 03:16 AM
