How do I tune with EcuFlash then write files with EvoScan?
Old Mar 27, 2012 | 04:49 PM
okevolutionVIII's Avatar
Originally Posted by 07EvoIX
try using EvoScan to read the ECU and confirm that it uploaded the map correctly. If it did, then upload the new map (one downloaded from EvoScan) which will ensure you are uplaoding a good HEX file.
If the car still doesnt start, then it is the map which needs adjusting
cheers
So lets say the image written to the ECU is named "Map #1.hex", when the image is read, it will show up as what it was named, correct?
Old Mar 28, 2012 | 05:28 AM
pupo's Avatar
I have the same problem, I have an older cable and I can't use ecuflash 1.42, with the hack I can go up to 1.38, the problem is like somene else said, licence, if you had a valid licence you could get the cable to work, but evoscan should work for read and write(2.8 and up), if you notice on ecuflash you could save the file as .hex or .bin so I do not see any problem, I will be doing this soon so I just will update how it when, but it should work just fine.
Old Mar 28, 2012 | 08:32 AM
I checked this out last night. I put in a random scaling for the injectors in EcuFlash, saved the file, wrote it to the ECU, then read it which saves it as a "FlashImage" file with the time & date next to it. I opened that file in EcuFlash and the scaling matched so all good there.
Old Mar 28, 2012 | 05:48 PM
07EvoIX's Avatar
os now you know that you can flash with EvoScan. If the car is still not starting, the issue is the map.
though now that you have the initial things sorted, you should be able to get your tuner to sort the rest out.
cheers
sba
Mar 30, 2025 10:44 AM
Leftbehind126
Jan 1, 2013 01:49 AM
nikos_paps
Dec 23, 2012 11:02 AM
Hollywood_Evo
Nov 8, 2011 06:22 AM
cij911
Aug 12, 2010 11:46 PM
