Need help with a question
Old Mar 27, 2012 | 07:09 AM
STLEVOIX's Avatar
First post, I bought an Evo IX used and was told it had an ECU flash on it. What all am I going to need to get to be able to access and edit the ECU?
Thanks in advance,
Dillon
Old Mar 27, 2012 | 07:14 AM
jrank3792's Avatar
A tactrix cable, ecuFlash and evoScan. (both are software).
That is if you know what you're doing. If you don't, find a local tuner.
Old Mar 27, 2012 | 07:55 AM
MyEvo8Urs's Avatar
Don't bother if your asking this question. Seriously you will blow your motor up. You are playing with fire.
Old Mar 27, 2012 | 08:11 AM
STLEVOIX's Avatar
What type of program would I want if I wanted to tune out an 02 sensor from throwing a code?
Old Mar 27, 2012 | 08:33 AM
Raptord's Avatar
First you would want an internet browser in order to read the important threads in this section before trying to mess around with your ECU.
Then you would need ecuflash.
Rear or front o2 sensor?
Old Mar 27, 2012 | 05:21 PM
awdordie's Avatar
he needs a search bar. im assuming the one at the top of evom is broken for the op so i provided one...
http://lmgtfy.com/?q=what+is+ecuflash
seriously though. you need to go into the stickies and be prepared to have you mind blown at all the reading you are going to need to do before even thinking of flashing your ecu. i also suggest getting on youtube and searching for "how to tune an evo" the guys name on there and on here is r3compil3. i also suggest you search for merlins guide to tuning an evo. its a very large pdf that covers a ton of information. thats about all that we can spoon feed you. the other stuff your going to have to learn on your own. best of luck to you and dont get ahead of yourself.
Old Mar 30, 2012 | 08:22 AM
EvoRuss's Avatar
All the r3compile videos are in the sticky threads. Watch those and then after that watch them again. Then after that watch them again.
Old Apr 2, 2012 | 04:41 AM
Ramatzio's Avatar
That's my goal for Easter 2012
2015evoX
Jul 9, 2016 02:34 PM
jameswwt
Feb 15, 2016 05:59 AM
Mad Gorilla1911
11
Jun 23, 2009 09:26 PM
Bar
Sep 4, 2008 05:10 PM
tato_dc
Dec 19, 2007 01:03 PM
