SD: 3d ve table
Old Apr 9, 2012 | 01:15 AM
justastockevo's Avatar
SD: 3d ve table
i'm having a bit of trouble converting to SD and adjusting 3D ve table.
my values are going up to 190 points and car doesn't seem to react.
do i run too big of a value and should adjust scalings instead?
any 3d ve table examples, besides those already listed on forums? or someone i can speak with on the issue?
thanks!
Old Apr 9, 2012 | 08:54 AM
And's Avatar
And
post up your rom with a log so that I can see whats going on then could make some suggestions
Old Apr 10, 2012 | 01:33 AM
ok, found out a little bit, it seems that kpa-to-load should be used as rough adjustment and VE table is more of a fine tuning. this way VE values don't go thru the roof and fuelling is more or less predictable.
i'll keep playing with that and will report findings.
