MAF IAT WGDC correction on SD
Recently converted to SD via a 9653 rom from the SD threads.
When trying to tweak it in(before realizing and fixing the sensor scaling option was improperly set for the mapve table
) my boost was way different from what it had been before. The WGDC was tremendously lower. 0'd out the MAF IAT(it was set to pull 10-15% in colder temps) and it's all better.
I'm using the gm iat wired into the MAF IAT ADC, is this table no longer correctly useful or is something else awry?
) my boost was way different from what it had been before. The WGDC was tremendously lower. 0'd out the MAF IAT(it was set to pull 10-15% in colder temps) and it's all better.I'm using the gm iat wired into the MAF IAT ADC, is this table no longer correctly useful or is something else awry?
