Boost Settings for HKS EVC 5 w/ AMS-750 Turbo(3076)
Old Apr 23, 2012 | 07:21 AM
23r0k001's Avatar
Can someone please shed some light on the proper BOOST settings for my ROM(88590715). It seems as though I cannot get past 100Kpa(15psi). I'm guessing that is waste gate pressure.
As far as the HKS EVC 5 I was able to set it to EXTERNAL wastegate(P.O.) and test various boost curve settings. Boost curves are set at A(75%) and B(25%). Neither setting gives me higher than 100Kpa. Lowest maybe 94Kpa. I was thinking it may be some setting within the ROM?
Please Advise,
Old Apr 25, 2012 | 01:13 PM
todd6027's Avatar
are your using the ebc to control boost or the ecu
Old Apr 25, 2012 | 01:59 PM
23r0k001's Avatar
Using the ebc to control boost.
Old Apr 25, 2012 | 03:38 PM
todd6027's Avatar
then its nothing in the ecu , make sure its piped correctly and follow the insructions to set the boost level
http://www.google.ie/url?sa=t&rct=j&...wjp9PWS_7wBHtg
Old Apr 25, 2012 | 04:23 PM
23r0k001's Avatar
Do you guys think I should disconnect the stock boost selonoid?
Also, Are these considered the same. I can id some inconsistencies. I would like to know which one to follow;
OR
OR
I have tried to do all of these at one time or another and have received the same baseline boost(0 setting on hks evc 5) of 93-100kpa, Which is good. the problem is when I turn up the boost n the boost remains the same. I'm thinking my hks solenoid. But then when I connect the top of the Tial wastegate to the hks leftmost port, it goes way up to 233-240kpa. So before I start a final test n buy some vacuum lines and Ts, I would like the final word on which one to follow in order to see if my hks solenoid is busted.
Today's Daily Double..(Alex Trebek voice...)
Todd u have a IV w/ mivec? The IV is really my favorite since Jackie Chan's "Who Am I" movie. Have any pics?
Old Apr 27, 2012 | 05:39 AM
todd6027's Avatar
lol il have a look for some decent ones
doesnt matter if you leave the stock solenoid connected electrically but blank the pipes
from boost source (turbo out) to T piece then to middle pipe (inlet)on evc solenoid and other side of T bottom of the wastegate
top of wastegate to out on solenoid
small pipe on evc solenoid to inlet manifold after the throttle body
Old Apr 30, 2012 | 03:00 AM
23r0k001's Avatar
Ok piped as shown on the hks manual n still now now heavily over boosting to 240kpa+. Looking into the PO/SW settings.
SWOLN
Oct 15, 2015 11:07 AM
unihappytime
19
Sep 2, 2012 02:12 AM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
cec12789
Aug 8, 2009 01:35 AM
CO_VR4
Aug 25, 2006 11:48 AM
