default 1byte eval
default 1byte eval
Is (x1.2) the default eval value in evocan for load 1byte? I seem to have previously changed it to 1.3 to match a 2byte-to-1byte factor in a spicific rom file. But now, with other roms, 1byte readings seem less accurate! Should I change eval value back to 1.2?
Yes, it has to match up to what your ROM has for "2 byte to 1 byte factor". Easy to change, and don't be scared becoz all it does is reading/logging you won't break anything by changing the value...
