Rom 8858 AUDM to 8859 USDM
Old Jun 8, 2012 | 12:16 PM
StefanoIX's Avatar
Hello, as the title says, I want to know if it possible to change my Evo 9 AUDM ROM 88580014 to an USDM 88590015? This way I will be able to use V7 and other patches.
Thanks
Old Jun 8, 2012 | 12:55 PM
211Ratsbud's Avatar
Im using 8858 in place of 8859 go for it.
Old Jun 9, 2012 | 01:51 AM
justastockevo's Avatar
it's not really a AUDM rom (opposite to ecuflash definition). from what i've learned it's general market rom, GM in mitsubishi's language.
you can still use 8858 rom, there was a lot of porting work done, there's tephra's v7 set of patches for it and much more if you search.
if you really would like to use 8859 rom on your car, you'll need to disable EGR subsystem, as well as fuel temperature/pressure checks.
Old Jun 9, 2012 | 10:12 AM
211Ratsbud's Avatar
If the link for 885807 is broke i can send you that rom with xml.
Old Jun 9, 2012 | 12:54 PM
StefanoIX's Avatar
thanks for the info, I can use the V7 88580714, link was good, already downloaded
The thing that I still don't know is how can I use the JDM Map Sensor to log boost. While searching I saw that the others 8858 did't came with the map sensor. My car has from factory a 1 bar map sensor. What should i change besides the sensor to make it work? disable EGR?
Old Jun 9, 2012 | 03:54 PM
211Ratsbud's Avatar
disable EGR for sure, and just log boost with the proper equation in the evoscan.
Old Jun 10, 2012 | 07:21 PM
newpassport's Avatar
good job
Raceghost
Sep 19, 2016 11:35 PM
Zunk87
Sep 1, 2016 03:22 PM
Zunk87
Aug 31, 2016 03:10 AM
aquaplane
Jul 19, 2016 11:39 AM
foxbat
Apr 21, 2013 02:38 PM
