immobilizer help needed.
Old Jun 27, 2012 | 12:37 AM
babaz7's Avatar
Originally Posted by golruss
The first thing you need to do is to set your injector size scaling (under 'Main Fuel Setting')and your injector battery voltage latency compensation (under'Global Fuel Settings). Do this and your car should idle somewhat, then go from there.
Ps. You may want to talk to Tscomp a member on here who will take care of all this for you. http://www.tscomptuned.net/
thanks that worked! i just set the injector latency like my previous rom and now it idles...
but now im seeing couple of problems...
1.when i rev to like 6000 rpm while standing still and immedietly leave the throttle,the car almost dies and then after a couple of seconds is at the RPM i set, which is 1100...i havent taken the car out for a drive yet, what causes this?
2.i set the launch limiter at 5000 but the car goes to whatever RPM i take it to for example 9000...do i have to set MUT tables or something like that?
and again do i have to use the BIG MAP translator to convert my previous fuel and ignition tables to my new v7 rom?
Old Jun 27, 2012 | 12:38 AM
babaz7's Avatar
and thanks guys for all the support,you just need to help me a little bit more and i'll be gratefull to you guys!
Old Jun 30, 2012 | 09:22 PM
HyperDisorder's Avatar
I know that there's a thread somewhere on evom about all the rom changes you'll need to get launch limiter working on a 3 plug ECU with a 9653 based rom. It's probably worth Google searching for it, as the search function on evom isn't as good.
Yes you do need to use the translator, too.
Old Jul 1, 2012 | 08:44 PM
babaz7's Avatar
thanks man, i'll search for it and report back.
mady4g63
Nov 27, 2014 12:38 AM
secretagentstv
Oct 5, 2014 12:13 PM
whitersevo
Apr 28, 2013 06:12 AM
EvoCrazyyy
Dec 11, 2011 04:52 AM
nismo1982
Sep 1, 2009 05:12 PM
