Noob, need help
Old Jun 25, 2012 | 05:39 AM
DarkEvo's Avatar
Noob, need help
So I purchased EVOscan and i can't get it to work. I'm using the Tactrix 2.0 cable and Dell laptop with OS XP. When I plug everything in, turn the key to on, and try to run the DTC option I get:
Not sure what the issue is. Can anyone offer some advice?
Old Jun 25, 2012 | 06:52 AM
wazzelby's Avatar
For whatever reason I've never been able to get my DTC checks to work in Evoscan. I always get an error. Can you get it to connect and log?
Old Jun 25, 2012 | 07:21 AM
DarkEvo's Avatar
I clicked the star log and nothing happened there. A buddy thinks maybe the drivers for the EVOscan are not installed so I'm going to check that out after work.
Old Jun 25, 2012 | 10:42 AM
charlie.tunah's Avatar
Set the drop down at the bottom of your pic to "MUTIII EFI" and check/clear while the car is running. Just noticed that your drop down definitely says Evo 7/8/9, but Im fairly certain MUTIII EFI works for me. Im also using an older version of evoscan....
Even then, it still takes a few tries sometimes.
GL
Old Jun 25, 2012 | 12:48 PM
wtf_is_a_evo's Avatar
something else do you have the ECU unlocker? if so for some reason on my 2003 evo i have to have that running also in order to do DTC i have no clue why tho.
evo_tiago
Aug 4, 2012 11:21 AM
shrty10135
Dec 5, 2010 09:48 AM
izzyevo
Jan 29, 2010 11:06 AM
puckadog
May 18, 2007 11:48 PM
Taimur
Mar 9, 2006 05:14 PM
