How to set a Evo 6 ecu to full time Open Loop?
Old Jun 25, 2012 | 10:51 AM
jameswwt's Avatar
Hi,
can someone share on how to set the evo 6 ecu to operate full time open loop?
What is the advantage & disadvantage?
Thanks
Old Jun 25, 2012 | 06:13 PM
211Ratsbud's Avatar
advantage is full control over AFR when CL cant: IE super aggressive cams and idle on MAF. Also during cruise you can lean out some, or richen to your desire. Bad things.. your compensation abilities are decreased slightly and your AFR for a given setting may vary a little more during weather conditions.
I run full open loop.
Old Jun 26, 2012 | 02:57 AM
jameswwt's Avatar
Thanks for sharing and how do make it full time open loop on a 6 ecu?
Old Jun 26, 2012 | 03:13 AM
stunt2's Avatar
put your open loop tps/load thresholds lower
Old Jun 26, 2012 | 07:45 AM
wreckleford's Avatar
Some xmls have a minimum coolant temp for closed loop defined also. If you set this to a temp that the coolant never reaches it will achieve the same effect and is quicker to do as you are only changing one value.
Old Jun 26, 2012 | 09:45 AM
stunt2's Avatar
that will trigger cel after some time I believe. as well as disabling it via peripery bits does
Old Jun 26, 2012 | 10:55 AM
jameswwt's Avatar
Hi Stunt2,
which is the one that i need to adjust?
1) Open Loop Load 1?
2) Open Loop Throttle Low Load?
Will switching to a full time open loop effect the existing tune/map?
Thanks
Old Jun 26, 2012 | 11:24 AM
dolphin888's Avatar
You can adjust both maps. It will affect you closed loop area, so yes, we can say it will affect your tune.
Old Jun 26, 2012 | 11:38 AM
jameswwt's Avatar
Thanks but how to make it to a full time open loop? Which area should i set it and what is the figure should i increase or decrease?
Thanks
Old Jun 26, 2012 | 12:30 PM
stunt2's Avatar
set all values in both that tables say at 10
it means that when the car passes 10% tps or 10 load it will enter open loop. but average tps is 12-14% at idle, and load is somewhere 30-40. so the car is always above that (10) threshold and thus constantly in open loop
it may affect roughly 0-80 load and 0-4500 rpm area, so check your afrs in that cells
Old Jun 26, 2012 | 01:19 PM
Not with the 7-9 ECUs it doesn't. I have done it many times this way, never had a CEL. I can't say for sure with the 5-6 ECUs.
Old Jun 26, 2012 | 02:03 PM
dolphin888's Avatar
I can confirm this as well.
Old Jun 26, 2012 | 02:12 PM
dolphin888's Avatar
Thanks
For example:
Attached Thumbnails How to set a Evo 6 ecu to full time Open Loop?-openloop.png
Old Jun 26, 2012 | 05:57 PM
jameswwt's Avatar
Thank you so much Dolphin...
So, i just set all the values as per yr pics right?
Old Jun 27, 2012 | 01:45 AM
dolphin888's Avatar
Yes, but it may be, that you have % instead volts in TPS maps because of different scaling.
