Fuel cut multiplier on 96260709
Old Jun 27, 2012 | 10:09 AM
EvocentriK's Avatar
Anyone happen to have the code for the fuel cut multiplier same as the 9653 v7 rom has? Otherwise limited to 319 load.
same as this but with the correct addresses for 9626:
<table name="Fuel Cut Multiplier" category="Global Fuel Settings" address="12a70" type="2D" level="2" scaling="Hex16">
<table type="Static Y Axis" elements="1">
<data>To use "Fuel Cut Load x1" = 0x6DDD To use "Fuel Cut Load x2" = 0x4D00 :</data>
</table>
</table>
<table name="Fuel Cut Load x1" category="Global Fuel Settings" address="3614" type="2D" scaling="LoadBoost">
<table name="RPM" address="702c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Fuel Cut Load X2" category="Global Fuel Settings" address="3614" type="2D" level="2" scaling="FuelCutLoadX2">
</table>
Old Jun 30, 2012 | 10:43 PM
HyperDisorder's Avatar
<scaling name="FuelCutLoadX2" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="2" storagetype="uint8" endian="big"/>
<scaling name="LoadBoost" units="%" toexpr="x*5/4" frexpr="x*4/5" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="big"/>
<table name="Fuel Cut Multiplier" category="Global Fuel Settings" address="12B5C" type="2D" level="2" scaling="Hex16">
</table>
</table>
<table name="RPM" address="6298" type="Y Axis" elements="9" scaling="RPM"/>
</table>
</table>
<table name="Fuel Cut Load Trigger Delay" category="Global Fuel Settings" address="159a" type="2D" level="2" scaling="Time">
<data>FUEL CUT will not engage until the limit has been exceeded for this duration of time:</data>
</table>
</table>
Untested, but if the addresses listed for 9653 are correct, then these are correct too.
