Fuel Trim, Scaling & Latency Question
Old Jul 9, 2012 | 06:54 PM
  #46
jameswwt's Avatar
Originally Posted by 07EvoIX
whats the max load you hit on a 3rd gear WOT? that will be your max load.
also you cant just change your load cells without adjusting your fuel and timing maps.
cheers
Hi 07EvoIX,
but dont it seem that my timing & feul map is smoothen after the load adjustment?
Pls advise.
Old Jul 9, 2012 | 10:25 PM
  #47
07EvoIX's Avatar
after changing your load points your map will be off.
have a look at the the 2 screenshots you posted. for 100 load @ 2k RPM, your original timing was 17*, now after adjusting your load cells, your 100 load @ 2k RPM is 26*.
when you adjust your load/rpm cells, you need to also adjust your map accordingly. you cant just change the numbers and expect everything to work correctly as that will not occur.
basically the map values need to be moved in line with the load/rpm cell changes. that is, you need to move your old 100 load range to the new 100 load area. and do the same for the other cells that were modified.
then for the new load cells you created, i would start by interpolating horizontally and then go log and tune for better accuracy.
the same theory applies to your fuel map aswell.
cheers
Old Jul 11, 2012 | 06:18 AM
  #48
jameswwt's Avatar
Thank you 07EvoIX...
Old Jul 22, 2012 | 03:52 AM
  #49
jameswwt's Avatar
Originally Posted by Boosted Tuning
Did you reset your ECU and fuel trims?
For me to help you, I need you to reset your ECU, load the settings I gave you, let the car idle for 20 mins and then go on a 30 mins cruise, then report back the low and mid fuel trims.
Again, if you wanna fix your stalling issue, the first step would be to go back to a recirculated BOV.
Hi Boosted Tuning,
im happy that my staling problem were resolved after i plumbed in my synapse bov.
Can you help me on my last problem as ive always hope to improve my Throttle Response as whenever i immediate full throttle, my afr deeps til 10afr and ive to immediate partial throttle and wot again only than my car catapult.
Can i adjust on the Accel Enrichment?
Should i increase or decrease the %?
Thanks
Old Jul 25, 2012 | 04:48 AM
  #50
jameswwt's Avatar
Hi Boosted Tuning,
here is my latest Cruise log & Idle log for your kind advise.
Please note that the Latency values in Cruise log is slightly different (0.024ms each) compare to Idle log. Please refer to attachment.
Im sorry that the files is still over 100KB after compress so im unable to post my logs & map here...
Old Jul 25, 2012 | 02:30 PM
  #51
07EvoIX's Avatar
use a filesharing site like dropbox or something
cheers
Old Jul 26, 2012 | 06:05 AM
  #52
jameswwt's Avatar
Hi Guys,
here is my Idle& Cruise Logs
Fast_Freddie
Oct 30, 2023 01:56 AM
goofygrin
36
Jun 27, 2017 11:17 AM
cplillges
May 25, 2017 04:33 AM
Raceghost
May 21, 2016 12:37 PM
