560's maxed out at 14 psi ?
Old Jul 10, 2012 | 01:06 PM
stunt2's Avatar
as above, they maxed out 99% @14 psi in 6-7K rpm region, with 11.5 afr
car is 2.3 with S2 cams and 10.5 turbo, pump gas, hardwired wallbro 255
do you guys find it normal ? or should I look for some leaks ? there were no major leaks according to my las check, only from bov
SOLVED
replaced old walbro with new one along with new rubber hose and clamps. dunno which one was faulty but all is good now
IDC is ~70% to the redline at 10.5 afr
Old Jul 10, 2012 | 01:16 PM
evodriver49's Avatar
youre not "maxed" yet at 100%. i believe 110% is around where injectors are at their limit
https://www.evolutionm.net/forums/ec...cle-110-a.html
Old Jul 10, 2012 | 01:20 PM
stunt2's Avatar
I knew that 90-95% is safe limit, to leave a bit headroom also
anyway, is it normal ?
Old Jul 10, 2012 | 01:59 PM
JohnBradley's Avatar
Fuel pump install or your boost gauge is off.
Old Jul 10, 2012 | 02:04 PM
stunt2's Avatar
don't quite understand your post. you mean I need new walbro ?
Old Jul 10, 2012 | 02:06 PM
Did you use the install kit with the 255? Did you put the O ring and collar back on top of the fuel pump when you reinstalled it into the housing? I am saying the fuel pump install is allowing fuel pressure to bleed off and thats why its maxed out.
Aaron
Old Jul 10, 2012 | 02:15 PM
stunt2's Avatar
don't know to be honest. it was installed by previous owner
can it also be something related with bad fpr ?
Old Jul 11, 2012 | 03:10 AM
stunt2's Avatar
forgot to mention, car hit 265 load at that 14 psi. does't it tell anything about increased airflow and increased IDC ?
Old Jul 11, 2012 | 12:19 PM
stunt2's Avatar
bump
Old Jul 12, 2012 | 12:24 PM
todd6027's Avatar
Aaron
evo4 have a different set up , no plastic tank units or 0 rings in these babies
Old Jul 12, 2012 | 01:15 PM
stunt2's Avatar
so is it wothless to dig into the fuel tank ? considering that it requires dropping the tank to acces pump on IV's
Old Jul 12, 2012 | 01:17 PM
todd6027's Avatar
it would be very unusual for anything to be wrong in there
Old Jul 12, 2012 | 04:44 PM
EVO'D8's Avatar
hopefully your boost gauge is off
Old Jul 21, 2012 | 10:58 AM
stunt2's Avatar
leak tested today and have leak from bov, but not such critycal to be the cause of such big load
Old Jul 22, 2012 | 09:29 AM
Dynotech Tuning's Avatar
Have you messed with the MAF scaling? That will alter your load levels.
-Jamie
