ISCV address request - evo 9
Old Jul 10, 2012 | 06:20 PM
nwa7265's Avatar
can someone please provide me with the address info for Desired ISCV intial step position with AC off-Neutral for an evo 9 usdm rom 8859*
thank you
Old Jul 10, 2012 | 06:50 PM
Raptord's Avatar
Code:
<scaling name="ScaleBase64Adder" units="Mult. Factor" toexpr="(x+64)/64" frexpr="64*(x-1)" format="%.2f" min="0" max="10" inc="0.05" storagetype="uint8" endian="big"/>
<scaling name="ISCV_AX2_8" units="% Demand" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="200" inc="0.5" storagetype="uint8" endian="big"/>
<scaling name="ISCV_AX2_16" units="% Demand" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="200" inc="0.5" storagetype="uint16" endian="big"/>
<table name="ISCV Demand Target Idle Trim (sub_1ECF6)" category="ISCV Control" address="3dec" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Target Idle Deviation" address="6c9e" type="Y Axis" elements="9" scaling="RPMTarget"/>
	</table>
	<table name="Target Idle ISCV Trim Adjust Frequency" category="ISCV Control" address="14c2" type="1D" level="2" scaling="Time"/>
	<table name="ISCV Demand Below 500 RPM Idle Recovery Adder (sub_1E2C8)" category="ISCV Control" address="1516" type="1D" level="2" scaling="ISCV_AX2_16"/>
	<table name="ISCV Demand Startup CTS Adder (sub_1EBB8)" category="ISCV Control" address="3d60" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Coolant Temp" address="6fde" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="ISCV Demand General CTS Subtractor (sub_1EBE6)" category="ISCV Control" address="3e0a" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand Baro Adder (FFFF6E98) (sub_1E1EE)" category="ISCV Control" address="3dda" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Baro" address="6e28" type="Y Axis" elements="5" scaling="Baro16"/>
	</table>
	<table name="ISCV Demand RPM Adder* (sub_1EFC0)" category="ISCV Control" address="41d8" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="RPM" address="6b7a" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="ISCV Demand TPS Subtractor* (sub_1EFC0)" category="ISCV Control" address="6810" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Shifted TPS" address="810c" type="Y Axis" elements="11" scaling="ThrottlePercentage"/>
	</table>
	<table name="ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph] (sub_1EFC0)" category="ISCV Control" address="65de" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="RPM" address="7fb0" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="ISCV Demand CTS Adder AC Off - Neutral (sub_1F1F8, sub_1EA0C, sub_1F596) [sub_1EFC0]" category="ISCV Control" address="3d38" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Coolant Temp" address="70c2" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="ISCV Demand CTS Adder #2** (Post WOT) (sub_1F1F8) [sub_1EFC0]" category="ISCV Control" address="54e6" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Coolant Temp" address="7070" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="ISCV Demand CTS Adder AC On - Drive (sub_1F2C6, 1F596) [sub_1EFC0]" category="ISCV Control" address="51b0" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand CTS Adder AC On - Neutral (sub_1F2C6) [sub_1EFC0]" category="ISCV Control" address="3d4c" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand CTS Adder #2*** (Post WOT) (sub_1F2C6) [sub_1EFC0]" category="ISCV Control" address="5502" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand RPM Adder (Moderated by Baro, IATS) (FFFF6EA8) (sub_204B6) [sub_1EFC0]" category="ISCV Control" address="672a" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="RPM" address="802a" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="ISCV Demand Baro Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0]" category="ISCV Control" address="6adc" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand IATS Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0]" category="ISCV Control" address="6ae8" type="2D" level="2" scaling="ISCV_AX2_8">
		<table name="Intake Air Temp" address="714a" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="ISCV Demand TPS Adder, AC off (FFFF6E84) (mattjin fuel cut delay)" category="ISCV Control" address="3d6e" type="2D" level="1" scaling="ISCV_AX2_8">
		<table name="TPS" address="6f9a" type="Y Axis" elements="7" scaling="ThrottlePercentage"/>
	</table>
	<table name="ISCV Demand TPS Adder, AC on (FFFF6E84) (mattjin fuel cut delay)" category="ISCV Control" address="3d82" type="2D" level="1" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand Power Steering Baro Adder**** (FFFF7C0E) (sub_1F6E6) [sub_1EFC0]" category="ISCV Control" address="6adc" type="2D" level="2" scaling="ISCV_AX2_8">
	</table>
	<table name="ISCV Demand CTS Adder (FFFF6E84)" category="ISCV Control" address="4e56" type="2D" level="1" scaling="ISCV_AX2_8">
	</table>
	<table name="Baro Mult. Factor for ISCV Demand Adder FFFF6E84" category="ISCV Control" address="6b68" type="2D" level="1" scaling="ScaleBase64Adder">
		<table name="Baro" address="6e4e" type="Y Axis" elements="5" scaling="Baro16"/>
	</table>
	<table name="Idle Stepper Lookup Table" category="ISCV Control" address="3e31" type="3D" scaling="ISCVSteps">
		<table name="Coolant Temp" address="7164" type="X Axis" elements="8" scaling="Temp"/>
		<table name="ISCV Demand" address="717e" type="Y Axis" elements="27" scaling="ISCV_AX2_16"/>
	</table>
Taken from : https://www.evolutionm.net/forums/ec...sassembly.html
Those are the "real" ISCV tables. The "desired ISCV initial step position" doesn't have the correct units for the right column.
The table you're looking for with the proper scaling is "ISCV Demand CTS Adder AC On - Neutral"
Old Jul 11, 2012 | 07:59 PM
nwa7265's Avatar
Thanks. Tom (Tscompusa) is wanting that table tho. Does that table exist?
Old Jul 12, 2012 | 05:50 AM
Raptord's Avatar
"ISCV Demand CTS Adder AC On - Neutral" is the same exact table. Just the units on the right column are correct.
Boosted Tuning
Aug 26, 2023 10:14 PM
mrfred
Aug 1, 2022 06:05 AM
simple_lancer
Oct 14, 2020 02:18 AM
hans512
Dec 29, 2016 01:15 PM
nikush
Nov 24, 2015 11:27 PM
