Need assistance with logging
Old Jul 23, 2012 | 07:04 AM
kid_19440's Avatar
Exclamation Need assistance with logging
Hi everyone I am trying to figure out the following. I own an Evo IV but I am running an Evo V ecu.
what I would like to know where or what pin do you connect the output from the wideband into the ecu so that when I do log with the SD I can have AFR added to that.
If I have to run a laptop along with the SD then it defeats the whole purpose of having the SD feature on the OP2.0
Any help will be appreciated. I am trying to do this safely as the only place I can log at WOT is the autobahn and there is no room for making mistakes there. I am trying to avoid having the laptop on the car in case I have to get on the brakes and I am trying to avoid needing someone every time I need to log.
Attached is a picture of the Evo V ecu pinout. I was thinking pin 76 but I need more assurance that this is the correct pin to use.
I hope you guys can help me.
Cheers
Old Jul 23, 2012 | 01:19 PM
akeric's Avatar
Last I heard SD logging on the 2.0 cable wasn't fully working.....would be news to me if its working now.
Old Jul 23, 2012 | 09:21 PM
kid_19440's Avatar
I just tried it with the SD working off the parameters I chose from the ecu. The AFR was one of those parameters and when opening the lob with Evoscan the program warned me that there was no AFR reading which is a true statement.
Bewstzalot
Jul 7, 2017 01:35 PM
gvr4v
Jul 19, 2016 09:00 AM
blockade35
Jul 12, 2016 08:52 PM
l2r99gst
Aug 25, 2009 12:13 PM
BlackonBlack2
10
Aug 6, 2007 06:36 PM
