How to Tune MAF Smoothing?
Hi,
just wonder do tuning maf smoothing improve response?
Its my same old problem where whenever i immediate full throttle, my afr will deep til 10afr which my car seems hardly accelerate.
Ive to immediately partial throttle and full throttle for 2 to 3 times only my car will catapult.
Ive done with my injector scaling and latency but with no improvement at all.
Have tried increase timing on lower load from 10~70 - RPM from 1000~2500
LS disable all the time and im on 850cc Sard injectors.
This is my last only problem which i dont mind to pay a contribution if whoever can help me on this issue.
Spec's :
gt3076r
S2 cams
85.5 piston
300 x 600 x 70mm IC
Or the fact is its Lazy Spool or The Bigger CC Injector that im using???
Pls do not ask me to go for ALS.
Spec's :
gt3076r
S2 cams
85.5 piston
300 x 600 x 70mm IC
honestly ive no choice as this is the only remaining problem i really hope to solve b4 i give up and go either for :
1) Change back to stock 560cc injectors
2) Smaller turbo
Most of my problem have been resolved and which ive got most of the kind advise & sharing in this forum...
You can't simply turn LS on and off without retuning your fuel map to compensate.
If you state your injectors are dialed in to at least +/- 5% low/mid trims then post 3rd gear logs starting from 2k to rev limit.
Make sure you log the following and NOTHING else.
- TPS
- RPM
- Timing
- Injector duty
- Injector pulse
- Knock
- Wideband AFR
- AFRMAP
- 2byte Load
- TPS
- RPM
- Timing
- Injector duty
- Injector pulse
- Knock
- Wideband AFR
- AFRMAP
- 2byte Load
I already told you via email, that your spool was where it should be (gt30+S2's=4000rpm peak boost). If you wanna improve response, go with a smaller turbo.
Also, if you having too much fuel during acceleration, mess with the accel enrichment tables.
- TPS
- RPM
- Timing
- Injector duty
- Injector pulse
- Knock
- Wideband AFR
- AFRMAP
- 2byte Load
- TPS
- RPM
- Timing
- Injector duty
- Injector pulse
- Knock
- Wideband AFR
- AFRMAP
- 2byte Load
yes and thanks for your kind advise as i understand that i cant expect my gt3076r response as a stock turbo but my main problem is the super rich afr whenever i immediate full throttle which make my car heavy until ive to immediate partial lift off and re-throttle again.
Lastly, mind to advise me on how to set the Accel Enrichment table for a better AFR & Response on my case?
I noticed that the A.E will adjust by itself everytime we adjusted the Fuel map or Timing map (I might be wrong)?
1) From which RPM should i start to dial?
2) To lower or increase the % for leaner or richer afr?
3) Do i need to retune my Fuel & Timing map again after adjusting the Accel Enrichment and other area i should adjust as well?
Thanks Jay.
jameswwt
17
Jul 18, 2018 02:14 PM
