Installed Omni 4 Bar Drove then SES light no start
So this morning before I headed to work I installed my new omni power 4 bar MAP drove to work ~20 miles, parked it. At lunch went out started it up drove around washed the car then went to the atm probably 5 miles total came back to work parked it. Went to leave work and the car only turned over did not try to fire at all. Looked at the codes it was throwing and I got P0335 Crank Position Sensor Circuit Malfunction P0113 Intake Air Temperature Circuit High Input and P0108 Manifold Absolute Pressure Circuit High Input....
I found one thread where a guy popped these three exact codes and it was a cam sensor.
I am thinking something may have shorted some how? Maybe fried the PCM? Let me know what you guys think. Thanks in advance!
Okay got that so not setting up the scaling has forced these three codes? I have put the stock map sensor in and im still getting the issues so what do you guys recommend try and set up the map for the 4 bar.
Yeah I tried that multiple times. Codes come back immediately the crank sensor code doesn't show up until you crank the starter. I was told it sounds like the MAF sensor and if I unplug it and try to start it it should start. I plan to try that as soon as I can.
