Modified XML, new tables not appearing in ecuflash
I think I am loosing my mind. I have done this plenty of times, but I think I need another set of eyes.
88591715 (Evo 9 on SD, pre-patched rom)
Trying to add MrFreds Jitter fixes
When I add the xml to the TephraMOD xml in rommetadata, regardless of what I do it will not appear in ecuflash. Restarted computer, moved file ect.
Am I missing something obvious?
Check the ROM Info. If it is inheriting from another XML, make sure you are putting the info in the correct file. Also, dbl-check you are in developer mode in ECU Flash just to be sure this isn't causing issues.
Do you have multiple version of ECUflash installed? Make sure you're making changes in the right ECUflash directory's definitions.
