Do i need to retune my Fuel & Timing after decreasing Injector C.C?
Hi Guys,
just for my personal knowledge, do i need to retune my Fuel & Timing Maps after decreasing from a bigger injector (850cc) to stock 560cc?
Since my ride output is below 380awhp can i just swap in the 560cc and set the factory Scale & Latency and remain the current map which is tune under 850cc injectors?
Thanks
Thanks
provided that the fuel trims are exactly the same as they were on the 850s, then no. But that is highly unlikely so the fuel map would need to be adjusted.
this should only be done after ensuring your fuel trims are at their best level.
cheers
cheers
say if i get my fuel trims at idle +/- 4.65 LTFT Low & LTFT InUse range is it acceptable?
To my exploration, usually the Scaling are the one which reflect my On boost & WOT AFR, thereby as long as my AFR is on the safe side during WOT & High Speed than i should not be too particular on the Idle trim right?
Mine is an Evo 5 so i cant log Fuel Trim Mid & High.
Do i need to bring down few deg's of timings after the smaller injector swap?
Thanks
4G63 DSM
78
Feb 17, 2017 05:05 AM
WTB[European]: evo 8 injectors
mrhussain
Nov 7, 2016 05:28 AM
